Non-square apron on new workbench
Forum topic by Michael James posted 06-20-2014 02:08 PM 1223 views 0 times favorited 10 replies Add to Favorites Watch
View Michael James's profile
Michael James
89 posts in 3075 days
06-20-2014 02:08 PM
Topic tags/keywords: workbench vise hand tool
I”ve been completing a “Matt’s Monster Workbench” over the past few weeks. I’ve glued up the top and glued on the apron. The holes for the vise are drilled and all was going well. I just finished flattening the top last night and realized that the apron is not square to the top anymore. I believe my mistake was waiting until I had both the apron and the top glued up and then flattening. Anyway, it’s a mistake – one of many that I will make through my life – but the trick is fixing it. From what I can see, I have 3 options:
1. Leave it – but I’m thinking if I edge planing a board, it may throw of the squareness of that edge? Is that correct?
2. Fix it on the bench – I’m thinking either trying to hand plane it square or, with the help of a 6 pack and a few buddies, muscle it across my little jointer. If I do fix it, what method would work? How will this impact the operation of the vise (if at all)?
3. Replace it – somehow cut that bad-boy off, get some new stock and start over.
Any thoughts on this? I could use your help…
-- Michael James - www.michaeljames.ca
10 replies so far
View Ralph's profile
Ralph
166 posts in 2160 days
#1 posted 06-20-2014 03:35 PM
Deleted———
-- The greatest risk is not taking one...
Michael James
#2 posted 06-20-2014 03:41 PM
@Ralph – not sure that’s the right post you replied to.
View johnstoneb's profile
johnstoneb
2942 posts in 2199 days
#3 posted 06-20-2014 03:49 PM
Hand plane it square.
-- Bruce, Boise, ID
View Buckethead's profile
Buckethead
3194 posts in 1895 days
#4 posted 06-20-2014 04:32 PM
This is a job for a hand plane. Which one depends upon how much stock is to be removed. How’s about a photo?
-- Support woodworking hand models. Buy me a sawstop.
View shampeon's profile
shampeon
1775 posts in 2210 days
#5 posted 06-20-2014 04:34 PM
Yeah, hand plane it. Get a square, run it along the entire apron and mark the high spots. Knock them down, repeat.
Michael James
#6 posted 06-20-2014 04:34 PM
I was kind of thinking the same thing. I guess my biggest concern in the the operation of the twin screw vise once I’ve squared up the apron. The holes won’t be perfectly square the to front of the apron anymore. I guess I’ll try it and see. Thanks folks.
Buckethead
#7 posted 06-20-2014 04:39 PM
There must be a little extra play in the holes, no? A bit oversized? If not, just make them a little bigger if they cause binding or such.
View Richard H's profile
Richard H
489 posts in 1707 days
#8 posted 06-20-2014 04:45 PM
How far out of square is it? It will affect the clamping ability of your vise as the jaws won’t come together flat unless you adjust the vise face to match but than as you mentioned you will have a angle to everything you clamp there which might very well throw off your work on the bench.
If it’s way out of square you might have to cut off the apron and square the underlying base than reattach it but that’s going to depend how much room you have to plane away the apron and how far out of square it is.
I am kind of in the same boat right now with a 4” thick X 14” X 5’ slab and I need to square up the front face to the bottom where the vise mounts. I wouldn’t even think of trying to safely put that thing on my jointer and it’s to thick to run though the table saw and to bulky to run though a bandsaw so I think hand planes is going to be the best option. A power planner would also be a good option but mine isn’t that far out of square so I think I’ll just do it by hand.
Michael James
#9 posted 06-20-2014 04:56 PM
@Richard – I may have to adjust the front vise jaw a bit. I think I’m far enough along that I can square the face, put the vise on the bench and see what happens. Unfortunately, it’s out almost 1/8” so it may cause a bit grief.
@Buckethead – there may be a bit of play there so I might be able to shim the vise thread nuts to compensate for the planing…
You guys rock…I have some good ideas. If all else fails, I just cut the stupid thing off and start again, I guess!
View exelectrician's profile
exelectrician
2327 posts in 2454 days
#10 posted 06-20-2014 06:57 PM
Use a circular saw with a 7 1/4” or larger blade, tight against a dead square clamped on fence, shave off the out of square portion. Then hand plane the remainder.
-- Love thy neighbour as thyself
