Cutter Head Bearing - Please Help
Forum topic by nicksmurf111 posted 06-20-2014 04:26 AM 1158 views 1 time favorited 18 replies Add to Favorites Watch
View nicksmurf111's profile
nicksmurf111
366 posts in 1326 days
06-20-2014 04:26 AM
Topic tags/keywords: planer help bearing press puller belsaw
So I’m replacing the cutter head bearings in a Belsaw 9103 that I got for a pretty good price. One bearing was noisy and I think it was off balance.
I got the bearing off the chain reduction side off. The shaft slid out with a little encouragement, and the bearing rotated out of the pillow block after a little heat and some encouragement with an air hammer. The part of the bearing beneath the locking collar did shatter, but it all came apart without damaging the cutter head shaft.
The bearing on the motor drive side will not budge. I have the pillow block taken off the machine. I’ve heated it, lubricated it, beat it with a dead blow hammer, and I think that it’s only moved like 1/16”. I can get the locking collar to move back and fourth on the bearing ever so slightly. My three jaw puller isn’t large enough to fit around the pillow block. I’m a little worried that any more beating can potentially break the pillow block. Should I support the pillow block in a hydraulic press and try pushing the cutterhead out (catching it before it hits the floor)? The bearing will not rotate out of the pillow block until the shaft is removed. So putting a bearing splitter or 3 jaw puller on the bearing is out of question.
I can take it to a machine shop, but I think they will gouge me on labor. Last time I took something, they charged me nearly $100 to extract two bolts out of some car spindles.
The bearings are “208” size with a 1 1/2” inside diameter and 80mm outside diameter to fit a pillow block. I decided to pick up some hc208-24 bearings. I really don’t know what HC stands for, and what makes it different than a RA bearing, but it seems like RA’s are out of production. The HC bearing has a eccentric cam locking collar which matches what is on the machine. Surprisingly, one of the bearings I received seems to be bad, so I need to deal with the Ebay seller. He said to grease it up, but that didn’t help. I’ll be posting a YouTube video of that tomorrow.
Thanks ahead of time!
-- Nicholas
18 replies so far
View TiggerWood's profile
TiggerWood
271 posts in 1481 days
#1 posted 06-20-2014 04:52 AM
Cut it off.
nicksmurf111
#2 posted 06-20-2014 05:04 AM
Like I wrote above, it’s inside the pillow block. I can’t damage thr pillow block because it’s proprietary. I need to slide the shaft out without damaging anything accept the bearing itself.
-- Nicholas
TiggerWood
#3 posted 06-20-2014 05:12 AM
So, the bearing is still on the shaft, and the bearing is also still in the pillow block? Hmmmm
runswithscissors
2604 posts in 1900 days
#4 posted 06-20-2014 06:57 AM
If you can figure out how to get it onto a hydraulic press, I think that’s your best bet. Sounds like one of those jobs where you can’t back up and can’t go forward. Hmmm. Better you than me.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1236 posts in 1588 days
#5 posted 06-20-2014 08:18 AM
Make friends with the guys at the mechanics shop. Bring a crate of beer and some cake friday afternoon. Share your fascination with mechanics stuff and offer them to parttake in you little puzzle getting the machine apart. An investement well worth the effort…
-- "Do or Do not. There is no try." - Yoda
nicksmurf111
#6 posted 06-20-2014 12:04 PM
kaerlighedsbamsen, I should. There is a young mechanic across the street from my work who is kind to me. He always does the work I can’t accomplish myself.
My bother-in-law has a press, but no tooling. I’m going to go fool with it tonight.
-- Nicholas
nicksmurf111
#7 posted 06-20-2014 02:14 PM
I took a picture of it this morning on my way out.
-- Nicholas
View waho6o9's profile (online now)
waho6o9
8070 posts in 2452 days
#8 posted 06-20-2014 02:23 PM
What’s that top secret formula for seized parts?
ATF + kerosene or is it, ATF + gasoline?
Automatic Transmission Fluid (ATF) mix with another ingredient
and apply until it’s freed.
Good luck now.
kaerlighedsbamsen
#9 posted 06-20-2014 02:41 PM
Pictures help a lot! Hmm that should be an easy job for a large, adjustable puller
nicksmurf111
#10 posted 06-20-2014 02:43 PM
Well, gasoline would be bad. I haven’t tried soaking it yet for any length of time. If I can’t get it apart with either a dead blow hammer or an air hammer (which usually works on everything), I’m concerned how much better a press could actually do.
-- Nicholas
nicksmurf111
#11 posted 06-20-2014 02:44 PM
kaerlighedsbamsen, what kind, like a large 2 jaw puller?
-- Nicholas
View Quanter50's profile
Quanter50
278 posts in 2171 days
#12 posted 06-20-2014 06:02 PM
I’ve had really good luck getting all kinds of seized metal parts apart with this stuff. It’s magic….I swear! Spray some all around and tap gently with a small hammer or block of wood. Like Frank’s Red Hot…..I put this sh!t on everything!
View TheFridge's profile
TheFridge
8671 posts in 1361 days
#13 posted 06-20-2014 08:14 PM
A press set up for it is the best way. If a press can’t get it I don’t know what will. A 2 jaw puller might work.
nicksmurf111
#14 posted 06-21-2014 12:03 AM
Will try the press tomorrow. I’m unsure if I’ll come up with adequate tooling.
-- Nicholas
runswithscissors
#15 posted 06-21-2014 12:16 AM
Any kind of hammering, even with a dead-blow hammer, involves some rebound. A press applies steady pressure without rebound. It’s the only way I know for really tough jobs.
