Loose tenon stock (outdoors)
« back to Joinery forum
Forum topic by ajthomas5009 posted 06-19-2014 11:12 PM 1376 views 0 times favorited 2 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1699 days
06-19-2014 11:12 PM
Topic tags/keywords: cedar joinery plans mortise and tenon loose tenon router outdoor table tip question
Hello everyone, I’ll be throwing together a picnic table and a planter bench very soon. It will be very similar to the outdoor rustic table M Spags did a cpl years ago. I’ll also be using WRC, I’ll be sticking with the 4×4 / 2×6 look and will also use loose M&T joinery. The main difference is that Ill be using a plung router/jig and that most of my 2×6 stock is only 4’ long. The project seems fairly straight forward and well explained but I have a couple joinery questions.
What should I use for loose tenon stock? Keep in mind this is an outdoor project. I’m juggling between using cedar or should I opt for a water resistant hardwood. W. Oak is my first thought here because of price. Also I was curious about tenon sizes for 8/4 & 12/4 stock. I was thinking 1” T x 4” L x 1” W for 8/4 stock and 2” T x 6” L x 2” W for 12/4 stock. Also if this was a interior project would ply make good tenon stock?
My next question has to do with design. I was tossing around the idea of assembling the top with a series of laminated mitered face frames to give it a unique design. I defiantly like the idea and look but am unsure how seasonal movement would effect it. I’m just looking for critique, advice and tips for this project so feel free to chime in.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
2 replies so far
View exelectrician's profile
exelectrician
2328 posts in 2509 days
#1 posted 06-20-2014 01:06 AM
I used the same material as the main project is made of.
In my case I used cedar tenons in a cedar frame glued with Titebond III as in my cedar bench project.
-- Love thy neighbour as thyself
ajthomas5009
#2 posted 06-20-2014 05:23 AM
Also I will prob be short on my 2×6x10’ stock (4) to finish the top so I might have to join some of the 4’s together for the top. What’s the best way to join 2 med boards to make 1 long?
