Doweling jig preferences????
Forum topic by Bill White posted 06-18-2014 09:50 PM 2073 views 0 times favorited 7 replies Add to Favorites Watch
View Bill White's profile
Bill White
5054 posts in 4080 days
06-18-2014 09:50 PM
Topic tags/keywords: jig
Is there a self-centering doweling jig that will allow centering of materials wider than 3/4” to 1”?
I often use table legs that can be a wide as 4” at the top, and find most jigs are kinda wimpy when it comes to workin’ with dowels that might need to be set on these thicknesses.
They’ll work well on aprons, but sorta “suck” when tryin’ to set up for thicker legs.
Ideas are welcome.
Bill
-- bill@magraphics.us
7 replies so far
View TiggerWood's profile
TiggerWood
271 posts in 1726 days
#1 posted 06-18-2014 11:27 PM
I use the $15 Joint Crafter Dowel Jig from Menards. I may have to clamp the jig to my work but I have never had a problem making the joints I was aiming for.
View Loren's profile
10477 posts in 3767 days
#2 posted 06-18-2014 11:36 PM
#3 posted 06-18-2014 11:42 PM
I have the heavier Jessem jig. It’s not self-centering but it’s
pretty cool for furniture and casework joinery. It can do
a flush corner joint, which most jigs don’t do.
I also have a Dowl-it but haven’t used it since I got the
Jessem.
If you’re serious about doweling and have the space, keep an
eye out for a used horizontal boring machine. I have one
with pneumatic plunge. It can’t do a cabinet corner joint
though, just frame joints. It can drill table legs I suppose.
View TechRedneck's profile
TechRedneck
769 posts in 2976 days
#4 posted 06-18-2014 11:51 PM
+1 for the Jessem jig.
It costs a bit more but is a heavy solid quality tool. I use it quite often, even for large projects. Once you get used to how it actually works, it can become your “go to” joinery tool for those small tables. I have a mortising machine but don’t use it as much as the jessem.
Now a good M&T joint is hard to beat for high stress joints, but in my research and experience, dowels make an excellent long lasting and strong joint taking a lot of force to break.
As always you still need to have flat, square stock to start with, but the Jessem allows you to get repeatable dowel holes in almost any size stock. You will find that if you want to replace a part or mess up a joint, it will allow you to reproduce the exact fit with a new piece. (Don’t ask how I know this!)
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View BJODay's profile
BJODay
526 posts in 2062 days
#5 posted 06-19-2014 02:29 AM
I have 2 dowl-it jigs. They have always worked well for me.
BJ
View lcurrent's profile
lcurrent
125 posts in 3935 days
#6 posted 06-20-2014 12:47 AM
This jig does stock from 1/4 to 6 inch mortise or dowel without changing anything
-- lcurrent ( It's not a mistake till you run out of wood )
View Marcus's profile
Marcus
1163 posts in 2139 days
#7 posted 06-20-2014 01:39 AM
Jessem jig fan as well.
