Plywood undersized router bits
« back to Joinery forum
Forum topic by woodworkingdrew posted 06-18-2014 01:30 AM 2314 views 1 time favorited 12 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1807 days
06-18-2014 01:30 AM
So I was all excited to use my new freud plywood undersize bits today. I used the 3/4 bit and the plywood didnt fit at all. Are there vaneer plywoods that are actual 3/4 thickness?
-- Andrew, California
12 replies so far
View sawdustjunkie's profile
sawdustjunkie
389 posts in 1915 days
#1 posted 06-18-2014 01:34 AM
Not that I have ever used.
The undersize router bits are sometimes not correct either.
When I use 1/2” plywood I have 3 different undersize bits to try and make the fit.
-- Steve: Franklin, WI
View TheDane's profile (online now)
TheDane
5545 posts in 3861 days
#2 posted 06-18-2014 01:40 AM
Steve is right … plywood thicknesses are all over the place. The only way I have found to get correct-width dadoes is to use an undersized bit and router dado jig that I saw in WoodSmith magazine …
http://www.woodsmithshop.com/download/204/adjustabledadojig.pdf
View RockyTopScott's profile
RockyTopScott
1186 posts in 3676 days
#3 posted 06-18-2014 01:47 AM
I use Whiteside plywood bits with good success but a jig like Gerry mentions above is almost fool proof.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View JAAune's profile
JAAune
1850 posts in 2515 days
#4 posted 06-18-2014 01:51 AM
If you want a perfect fit on every panel, the simplest method is to mill a dado 1/16” thinner than the plywood then use a rabbet bit and router table to size the edge of the plywood to fit the dado. The rabbet bit needs to cut the top side of the plywood as it goes through the router table to ensure each piece of plywood comes out with a tongue the exact same thickness.
The problem with trying to get a perfect fit straight off the router bit is that a sheet of plywood often varies 1/32” in thickness from one end to the next.
View Redoak49's profile
Redoak49
3661 posts in 2187 days
#5 posted 06-18-2014 01:58 AM
I think the best way is what is already mentioned using the router dado jig. It is as fool proof as any method out there.
View knotscott's profile
knotscott
8146 posts in 3573 days
#6 posted 06-18-2014 09:19 AM
Plywood thickness can vary a lot within the same panel depending on where you measure it, which makes it darn tough to find a bit that will fit perfectly. I used to spend a lot time picking the best looking veneer….now I spend time checking thickness uniformity.
View bondogaposis's profile
bondogaposis
5086 posts in 2549 days
#7 posted 06-18-2014 12:45 PM
No, not unless you get a hold of some really old plywood, thirty years ago plywood ran true to size, those days are over.
-- Bondo Gaposis
TheWoodenOyster
1317 posts in 2133 days
#8 posted 06-18-2014 01:48 PM
Andrew, the exact same thing happened to me about 2 weeks ago. I was really unhappy. I used a 23/32” thinking that was “undersized” and the plywood was still too thick. My initial reaction was just what you have stated – Is some veneer ply actually a true 3/4”? My conclujsion is yes. I have two different 3/4” veneer plys from different sources. Neither one fit the 23/32” dado. My guess is that the plywood itself is 23/32”, but when they add the veneer, it gets just a hair thicker, and ends up around 3/4”.
-- The Wood Is Your Oyster
TheWoodenOyster
#9 posted 06-18-2014 01:52 PM
That jig is nice and seems like it would work great. Thanks for posting that.
View bonesbr549's profile
bonesbr549
1576 posts in 3265 days
#10 posted 06-18-2014 02:01 PM
I’ve not seen 3/4” ply in a long long time. I run my ply over a bit on the table to take it down to a fixed width and leave a lip over the edge. Just like mortise and tenon, I cut the dado and cut the ply to fit the dado. Either take some off each side or leave a lip below. Mostly I do one side (bottom of ply) it’s much quicker.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2567 days
#11 posted 06-18-2014 02:59 PM
I have the Freud undersized plywood bit, ran into the same problem as you did. I ended up cutting a rabbet along the shelf edge, using an edge guide, to get it to fit. Next time I need to do it, I’ll be making that adjustable jig.
On an related note (related to the dado jig), I can’t find any place in town that carries 1/4” hardboard. The BORG only carries 1/8”.
View davidroberts's profile
davidroberts
1027 posts in 3684 days
#12 posted 06-21-2014 07:06 AM
I believe 3/4” Baltic birch plywood, and I mean true Baltic birch is manufactured as a true 3/4” thick, similar for 1/4” and 1/2” Baltic birch. It’s been awhile since I’ve had some in the shop. Of course moisture could affect plywood thickness, maybe just enough for “too” snug or just a hair loose, but so could the country of origin, manufacturing process, etc. I agree with the consensus that making an adjustable jig is time well spent.
I’ve seen free online plans for a dirt simple jig that works fine to a jig by Kent Shepherd http://lumberjocks.com/projects/17505 and also featured in Fine Woodworking magazine http://www.finewoodworking.com/workshop/article/how-to-build-a-dado-jig.aspx
that still makes me drool. The link to FWW may be members only.
-- Better woodworking through old hand tools.
