Delta Jointer 37-190 Blowing internal fuse
Forum topic by Mike posted 06-18-2014 01:02 AM 1049 views 0 times favorited 5 replies Add to Favorites Watch
View Mike's profile
Mike
2 posts in 1342 days
06-18-2014 01:02 AM
New at woodworking. Purchased a used Delta jointer 37-190 for $75. Worked fine for a while. Now when I put a load on it, it pops an internal fuse and shuts down. Puff of smoke. I can press reset button and it comes back on, but the same thing happens. Can anyone tell me what’s happening, and whether it’s worth fixing? Machine is clean otherwise, and does a great job.
-- Mike, Lancaster NY
5 replies so far
View Bogeyguy's profile
Bogeyguy
548 posts in 1971 days
#1 posted 06-18-2014 01:23 AM
Obviously a motor problem. Pull it off and take it to a motor repair shop to have it checked. May be something simple.
-- Art, Pittsburgh.
View WhyMe's profile
WhyMe
976 posts in 1464 days
#2 posted 06-18-2014 03:16 PM
Check all electrical connections and if using an extension cord, try it without.
View MrUnix's profile
MrUnix
6330 posts in 2102 days
#3 posted 06-18-2014 06:15 PM
I’m gussing you are talking about the thermal overload protectior on the motor? Try spinning the cutterhead by hand (using the belt) to see if there is any unusual resistance. If there is, take off the belt and try to isolate it to either the cutterhead bearings or motor. If the cutter head turns freely with the belt off, then it most likely is a problem with the motor, such as bearings going bad or a stuck centrifigual switch. If you can’t find anything unusual, try running the machine with the belt off and see if the problem still persists. If it does, then there is a problem with the motor and it will need to be opened up to determine what it might be.
View nicksmurf111's profile
nicksmurf111
366 posts in 1354 days
#4 posted 06-18-2014 08:38 PM
Smoke is bad. The suggestions above are good. Look for loose connections, stuck centripetal switch, don’t use thin/long extension cords or better yet no extension cords at all. Blow the dust out of the motor with an air compressor. Only run it on a 20 amp circuit. Chucking the motor in the trash and buying a used ~1hp motor would be cheaper than having it professionally repaired. Changing motor bearings is really easy, you might just need a puller and some basic hand tools.
-- Nicholas
View Mike's profile
Mike
#5 posted 06-20-2014 08:19 PM
Thank you all for the suggestions. I hope to work on it this weekend, and will report back as to my findings.
