Any bright ideas on how to open blast gate behind saw?
Forum topic by Jackietreehorn posted 06-17-2014 06:43 PM 1974 views 0 times favorited 30 replies Add to Favorites Watch
View Jackietreehorn's profile
Jackietreehorn
150 posts in 1810 days
06-17-2014 06:43 PM
In my previous setup I used a couple long rods and basic fulcrum points. In my new setup, the gate is now directly behind the saw so I have to make my levers work around a 90 degree corner. This is all I could come up with in a rough sketch, basically a notch that is angled that directs the other arm to move… Probably take me a while to build it while I scratch my head along the way. Thought maybe someone had some other way that would save me a lot of r&d. Thanks in advance!
As you can see my table is a bit big so there’s no easy access from left or right of saw
-- www.nobleprojects.blogspot.com
30 replies so far
View DLCW's profile
DLCW
530 posts in 2526 days
#1 posted 06-17-2014 07:31 PM
Put it further up the line towards the DC. I have a setup similar to what is pictured and my blast gate is at eye level and easy to get to. After the gate is a splitter that goes to the main dust port at the bottom of the cabinet saw and the other goes to a smaller hose attached to blade guard with dust collection built in.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
View Don W's profile
Don W
18561 posts in 2439 days
#2 posted 06-17-2014 07:33 PM
I hope you come up with something. I’m tired of reaching behind the saw!
View Elizabeth's profile
Elizabeth
817 posts in 3015 days
#3 posted 06-17-2014 07:35 PM
What are you connecting at the gate – a flexible hose, or a rigid pipe?
Where does that pipe/hose go to? What about leaving the gate on the saw open, and installing another gate at an accessible point in the pipe/hose run? On my shop the table saw dust port is also on the back of the saw. From the port I ran a few feet of flex hose to get round to the front right corner of the table, then a run of metal pipe goes straight up to the ceiling, and the blast gate is about shoulder height on that pipe. One of my shop photos shows it.
Don W
#4 posted 06-17-2014 07:45 PM
before I got my cabinet saw, I had this old craftsman, see the threaded rod is attached to the door on the blast gate. Pull to open, push to close.
Jackietreehorn
#5 posted 06-17-2014 08:10 PM
Because of room behind saw, the gate will have to be attached to saw, then a small section of flex, maybe a foot long and then to rigid pipe. The gate can’t go anywhere else, mainly cause I wasn’t planning on upgrading collection system when I started to design the new table. If I put it farther down the line it’d cut off the router table, or both saw and router would be open at same time.
Once I started building new table I started reading more about dust collection and decided to upgrade which means shoehorning a lot of stuff in limited space. Had I thought about it prior the story would be much different. Big doh! On my part.
View waho6o9's profile (online now)
waho6o9
8067 posts in 2449 days
#6 posted 06-17-2014 08:15 PM
Maybe wire cable on each side of the saw, one to open and the
other to close.
View MrRon's profile
MrRon
4564 posts in 3115 days
#7 posted 06-17-2014 11:34 PM
If you can find a choke cable at your auto parts store, you could rig it to open/close the blast gate with a push/pull action. Once you have the choke cable, it will become obvious how to rig it. http://www.summitracing.com/search/part-type/choke-cables
View Tony_S's profile
Tony_S
796 posts in 2955 days
#8 posted 06-18-2014 12:19 AM
pneumatic is the way to go of your mechanically inclined.
You can buy them pre made, but they can get pretty pricey.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
Jackietreehorn
#9 posted 06-18-2014 12:28 AM
Pneumatic sounds neat for cool factor, I can imagine parts could add up though. I like the cable idea, but was hoping to not spend any $$ if I can help it cause I blew budget from get go. I’ll call my hot rod buddy and see if he’s got extra cable somewhere.
View MT_Stringer's profile
MT_Stringer
3134 posts in 3103 days
#10 posted 06-18-2014 01:02 AM
@Tony. I like the air cylinder idea. Very nice. Luckily for me, I only have two blast gates and they are both within easy reach behind my saw.
View Steve Peterson's profile
Steve Peterson
362 posts in 2954 days
#11 posted 06-18-2014 03:27 AM
How about moving the blast gate further downstream? Is there another location that provides better access?
-- Steve
View TheFridge's profile
TheFridge
8656 posts in 1358 days
#12 posted 06-18-2014 03:38 AM
I wonder if a bicycle hand brake would work. You could spring load it fairly easy.
View William Shelley's profile
William Shelley
509 posts in 1341 days
#13 posted 06-18-2014 08:24 AM
I really like those pneumatic ones… and small air cylinders like that are a dime a dozen on ebay. The fittings are what come around to bite you though. A few bucks each doesn’t seem like much but it adds up quick.
-- Woodworking from an engineer's perspective
View mudflap4869's profile
mudflap4869
1549 posts in 1331 days
#14 posted 06-18-2014 12:26 PM
Just don’t do half measures, it costs more in the long run. A small can for each project. Add a few coins to each when you empty your pockets. I have bought some great tools that I otherwise could not afford by using that system. Never leave the house with coins in your pocket.
-- Still trying to master kindling making
View ChrisK's profile
ChrisK
1865 posts in 2953 days
#15 posted 06-18-2014 12:48 PM
Jackietreehorn,
Check out http://www.surpluscenter.com/ for the various pneumatic bits.
A few hours of tinkering should get what you need. An electric solenoid and a spring might also work.
-- Chris K
showing 1 through 15 of 30 replies
