looking to rip pvc? What tool should i use?
Forum topic by chetrog posted 06-17-2014 03:13 AM 1595 views 0 times favorited 22 replies Add to Favorites Watch
View chetrog's profile
chetrog
84 posts in 1335 days
06-17-2014 03:13 AM
For a project I am going to make a marble machine. The track I am going to be using is either 1/2 or 3/4 scheduled 40 PVC. I’m not sure what tool would i be using to rip the PVC. Maybe a plastic jig saw blade?. Thanks for any suggestions.
-- I had a stroke a few years back, and sometimes the words dont come out as well as I would like.
22 replies so far
13594 posts in 3212 days
#1 posted 06-17-2014 03:31 AM
make a ‘v’ grooved board
and clamp it in front of the bandsaw blade
centered
lay the pvc against a straight board
and draw a line along it
then keep the line up
as you run it thru the bandsaw
View TheFridge's profile
TheFridge
8643 posts in 1357 days
#2 posted 06-17-2014 03:32 AM
How long?
View Buckethead's profile
Buckethead
3193 posts in 1739 days
#3 posted 06-17-2014 03:35 AM
I’m going table saw.
-- Support woodworking hand models. Buy me a sawstop.
View Loren's profile
9760 posts in 3519 days
#4 posted 06-17-2014 03:38 AM
View robscastle's profile
robscastle
4707 posts in 2075 days
#5 posted 06-17-2014 03:43 AM
Fit a blade specifically for PVC to the table, I think they are negative rake and similar to a aluminum cutting blade.
Other wise do a test cut on some scrap and you may be comfortable with the result.
I cut perspex and lexan all the time on the table saw.
-- Regards Robert
chetrog
#6 posted 06-17-2014 03:55 AM
I don’t have a table saw, or a ban saw. Maybe i can make a little jig for a jig saw with sandwitching 2 2×4’s and use my jig saw.. Or i maybe i should “Man up” and buy a table saw… Thanks for the suggestions so far.
View crank49's profile
crank49
4028 posts in 2842 days
#7 posted 06-17-2014 04:31 AM
Band saw.
Table saw if you have an affinity for taking chances and doing dangerous crap.
But the first question should be, “Why not make the tracks out of wood?”
A “V” groove will work better than a round groove; less friction. And easier to make.
Buckethead
#8 posted 06-17-2014 04:33 AM
I would also make the V groove on the table saw.
View dawsonbob's profile
dawsonbob
2694 posts in 1626 days
#9 posted 06-17-2014 04:34 AM
I have to go with crank. “But the first question should be, “Why not make the tracks out of wood?”
A “V” groove will work better than a round groove; less friction. And easier to make.”
Bingo: he nailed it.
-- Mistakes are what pave the road to perfection
Buckethead
#10 posted 06-17-2014 04:35 AM
Tell us what tools you have, Chetrog. I gather that you have a jig saw, but that seems like the worst choice to me. the reciprocating action would be too unruly in my opinion. You could use a Circular saw, but then the need for a jig becomes more pressing.
chetrog
#11 posted 06-17-2014 06:15 AM
I’m a little slow since i had a stroke. I guess i don’t understand what the v grove that people are talking about. gonna google it now.
I own a Circular saw, mitter saw,drill, driver, and a jig saw.
View mtenterprises's profile
mtenterprises
933 posts in 2564 days
#12 posted 06-17-2014 12:20 PM
For safertys sake and for a person in your condtiton, stroke, I would build a jug that I could cut small diameter pvc with a utility knife. Something you could build on the jugsaw that would hold and clamp the pipe with a metal straight edge to run the knife along making several passes then turning the pipe 180 deg. and doing the same. I personally would stay away from the table saw for small diameter pvc. I have done it on larger size like 1 1/2” and up and that can get a bit scary. But each to his own, just one of the few things I wouldn’t do on a table saw.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View dhazelton's profile
dhazelton
2648 posts in 2167 days
#13 posted 06-17-2014 12:48 PM
I don’t understand the end result, but if you’re trying to rip a pvc pipe in half, I’d go bandsaw as well. You’d probably be better off with a metal cutting bandsaw as I think high speed might melt the pipe and gum up the blade and tires. But I never did it so I can’t say
View Dallas's profile
Dallas
3599 posts in 2358 days
#14 posted 06-17-2014 04:20 PM
Just kind of thinking here. DOn’t take it as gospel.
A V-groove is just two cuts with a table saw to make a 45° angle that sits on it’s point, like what welders and machinists do when welding pipe….. Set a piece of Angle Iron on it’s point and lock it in place, put the piece you want to cut in half in the angle and it won’t move.
YOu can make one with wood by using a table saw or a router, possibly a circular saw, although with the stroke you may not be able to hold the circular saw steady.
I would take available jig saw, cut a slot in a piece of aluminum angle and then put in a wood blade to or pvc blade in the slot. Hold the angle on it’s point with several F clamps or even C-clamps and a piece of wood on the top. If the angle is large enough, the pvc will slide under the clamp.
chetrog
#15 posted 06-17-2014 09:00 PM
Thanks for the information guy. I had a stroke about 3 years ago , for me just explaining stuff gets hard to understand. I can still use tools etc, thankfully. Thanks for all the suggestions.
