Grain Direction in Marquetry ??
Forum topic by Bigkahunaranch posted 06-16-2014 07:53 PM 1123 views 0 times favorited 4 replies Add to Favorites Watch
View Bigkahunaranch's profile
Bigkahunaranch
124 posts in 1475 days
06-16-2014 07:53 PM
Topic tags/keywords: veneer marquetry grain
Ok0 So I am very new to marquetry. I have learned a lot reading the blogs here and Boatwright has been great answering questions.
My first project is a three color palm tree, like the picture.
And I am going with the packet method and cut on a scrollsaw.
My question concerns the leaves. There are five of them, and they fan out.
So in order to get the grain to match the leaves, would I uses five different pieces of green veneer?
If so that would be five green, one brown for the coconuts and one tan for the trunk of the tree.
Now what if I wanted to segment each leaf to have the grain opposed on each one?
Would I use ten pieces of green veneer?
Thanks
Dave
-- To see samples of my work, please visit https://www.facebook.com/bigkahunaranch
View jmartel's profile
jmartel
7807 posts in 2117 days
#1 posted 06-16-2014 08:17 PM
I would do each leaf in 2 pieces, having the grain maybe 45 deg different to each other (22.5 degrees off of the centerline for each)
View shipwright's profile
shipwright
7966 posts in 2765 days
#2 posted 06-16-2014 10:56 PM
If you want to do Boulle style just make one layer in the green and accept the grain as it comes. The grain in most dyed veneer is quite plain and it should cause little problem. If you want to orient the grain in each piece you would be better of with either double bevel or piece by piece (classic) style.
My advice, since you are starting out would be to go with Boulle style and focus on the menial stuff like assembling the packet properly and following the lines as perfectly as you can.
If you want to give the leaves definition, you can cut in Boulle style, cutting each leaf in two pieces and then use sand shading along the spine to simulate three dimensions. This will be more dramatic than grain orientation in a dyed veneer with little character.
Good luck and keep us posted.
Bigkahunaranch
#3 posted 06-17-2014 10:05 PM
Thanks folks for the replies.
So I tried the Boulle style. My packet was Koa for the trunk, Dyed Green for the leaves, Aformosa for the coconuts, Birdseye Maple for the sand which I drew in, and plain cut Maple for the backgound.
The Bad:
I forgot to number the pieces ( I knew better).
Some of the leaf tips split at the ends ( should have taped them up-again I knew better)
I had lots of gaps on several pieces ( I checked my table to blade and it was at 90 degrees)
Worst of all, walked by a window with the tray holding the pieces and a good Texas breeze disoriented everything.
The Good: I learned alot.
After assembling what I could I gave myself a “D” grade.
But I know it will get better with practice.
shipwright
#4 posted 06-17-2014 11:15 PM
When you do Boulle style, make sure that you don’t crowd the pieces tightly together when you assemble. The cutting style means that there are kerf gaps and you can’t make them go away. If, however, you disperse them evenly they are almost invisible. There is a strong tendency to try to get tight fits as you start assembling but you will only end up with bigger gaps in other places. (Don’t ask how I discovered this.)
