Dowel Joints
« back to Joinery forum
Forum topic by ajthomas5009 posted 06-16-2014 03:18 AM 1125 views 0 times favorited 8 replies Add to Favorites Watch
View ajthomas5009's profile
ajthomas5009
296 posts in 1489 days
06-16-2014 03:18 AM
I was thinking about building some outdoor benches from cedar and want to go with dowels instead of M&T joints. I’ve done a little research on them and all the information is geared towards jigs. Is there a simple way to drill for dowels on a drill press?
If so could someone explain it or send a link on it.
-- Sometimes you're flush and sometimes you're bust, and when you're up, it's never as good as it seems, and when you're down, you never think you'll be up again, but life goes on.
8 replies so far
View TheFridge's profile
TheFridge
8649 posts in 1357 days
#1 posted 06-16-2014 04:04 AM
You could but what would you do if you had to drill into the end of an 16”-20” leg? That’s where the jigs become handy. Not to mention portable, fairly easy to use, and to be had for 20$-50$ or so.
View gtbuzz's profile
gtbuzz
427 posts in 2313 days
#2 posted 06-16-2014 04:21 AM
I suppose you could do it with a drill press, but you’d spend a lot of time and effort setting up stops and whatnot just to get repeatable results. Jigs are definitely the way to go; much easier and faster. Plus, as TheFridge mentioned, it’s gonna get real hairy trying to drill dowel holes in the end of a long stretcher while trying to use a drill press.
I use the DowelMax jig and love it. While it’s a bit pricey $250, iirc, it’s one finely crafted tool, and worth every penny IMO. They also have a “junior” model that doesn’t include all the bells and whistles of the top end model that starts at $99.
View hairy's profile
hairy
2595 posts in 3404 days
#3 posted 06-16-2014 12:08 PM
It can be done without buying a jig, if you make one. It can be done without a jig, if you take the time to do it right. I use dowels at times. I have made a pattern on paper,—like a gasket—, transferred that to hardboard or mdf to make a template. Usually this is just for layout, but if you make it sturdy and have a means to secure it to the workpiece, you could use it to layout and drill.
http://lumberjocks.com/projects/92121
I do this on small projects. You might need a stronger joint.
-- My reality check bounced...
View bondogaposis's profile
bondogaposis
4525 posts in 2223 days
#4 posted 06-16-2014 12:48 PM
I think that mortise and tenon joints are going to be a lot easier than trying to make dowel joints on a drill press.
-- Bondo Gaposis
16272 posts in 4090 days
#5 posted 06-16-2014 12:57 PM
The time and effort you would save by spending $50 on a jig would be well worth it, IMO. Plus, you would have the jig for use on future projects as well.
hairy
#6 posted 06-16-2014 01:56 PM
You could assemble, then drill and drive in a dowel from the outside. A peg instead of an internal dowel. Maybe leave it proud and it would be a nice detail. Just a thought…
View 7Footer's profile
7Footer
2569 posts in 1820 days
#7 posted 06-16-2014 03:45 PM
I just saw an interesting shop made dowel jig the other day, not sure how it would stand up after a lot of use, but it is a pretty clever idea. This one wasn’t on the DP though, just a handheld drill, but I suppose you could adapt it to the DP.
-- http://www.youtube.com/nrk411
View lcurrent's profile
lcurrent
125 posts in 3687 days
#8 posted 06-20-2014 01:16 AM
The best way is depending on how many different sizes you are going to have is from aluminum plate keep flopping it and you will be OK
-- lcurrent ( It's not a mistake till you run out of wood )
