Finding a Replacement Bulb
Forum topic by ramone posted 06-15-2014 06:00 AM 1031 views 0 times favorited 5 replies Add to Favorites Watch
View ramone's profile
18 posts in 1406 days
06-15-2014 06:00 AM
Hello, I need to replace a burned out bulb by my bench. It’s a tear-shaped 40 watt LED. As you can see by the picture below, my old bulb has the same stem as the new one, but the new one (or ones, I tried others
in the pack) is not working : / Although these bulbs seem interchangeable, apparently they aren’t.
Can anyone shed any light on this issue? (pun wasn’t intended, but since it popped up, I’ll go with it : )
Thanks for your help …
5 replies so far
View dawsonbob's profile
2780 posts in 1688 days
#1 posted 06-15-2014 06:13 AM
I maintain an apartment complex, and ran into the same issue with some outdoor lights. As it turned out, the bases on the new ones weren’t actually making contact, They were too fat just above the threaded portion: looks like yours have the same problem. I had to take them back and find some with bases that matched the old ones exactly.
Good luck. Hope that sheds some light on the situation.
-- Mistakes are what pave the road to perfection
View JoeinGa's profile
7733 posts in 1939 days
#2 posted 06-15-2014 11:44 AM
The bulb on the left (burned out one) has a “candelabra base” and you should be able to match it exactly at HD or Lowes. It’s also available in other wattages.
The CFL on the right is “supposed” to fit but as Bob said above you may have to search thru the pile to find one that doesn’t have the shoulder in the plastic where it meets the metal threaded part.
I had the same issue and just went with the old style.
View Sylvain's profile
696 posts in 2432 days
#3 posted 06-15-2014 01:50 PM
It seems the standard is not precise enough, as I have the same problem with similar bulbs (E14 socket) on a pendant made in Italy.
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View longgone's profile
5688 posts in 3241 days
#4 posted 06-15-2014 03:14 PM
I ran into the same problem with these bulbs when trying to change to some led bulbs on some ceiling fans. Obviously they manufacturers have some changes to make
View TheFridge's profile
9080 posts in 1418 days
#5 posted 06-15-2014 05:26 PM
Throw flood lights into the mix also. As an electrician, it’s becoming a pain to find led/cfl lamps that will work for a particular application. If it has a close fitting shroud/reflector around the lamp holder, you might want to put a close eye on it.
