Marble track suggestions? wood/pvc
Forum topic by chetrog posted 06-15-2014 04:10 AM 1540 views 0 times favorited 11 replies Add to Favorites Watch
View chetrog's profile
chetrog
84 posts in 1459 days
06-15-2014 04:10 AM
I really want to build a marble machine. The only problem is I’m stuck on what should i use for the track. The easy thing would be to just rip PVC and then use the track using pvc. I don’t have any skills to use wood as the track. I see a lot of people using refrigerator tubing and then using wire inside it , but I don’t want to really do that this way. I really would like to use pvc, but it will limit how i can make 90’s or it would look to square. Any suggestions on what i could use for the track. Im not a very creative person, but would like to build a project.
Also would anyone know of a easy way to lift the marbles. I would like it to be electric. Thanks for your time.
-- I had a stroke a few years back, and sometimes the words dont come out as well as I would like.
11 replies so far
View jmartel's profile
jmartel
7882 posts in 2145 days
#1 posted 06-15-2014 04:22 AM
You can rip pvc elbows with a hand saw for 90’s.
runswithscissors
2750 posts in 2020 days
#2 posted 06-15-2014 06:49 AM
PVC elbows also come in 45 deg and 22.5 deg (I think). You could combine these to get a semblance of a curve.
View MrRon's profile
MrRon
4764 posts in 3239 days
#3 posted 06-15-2014 06:19 PM
You could leave the elbows whole and cement the split PVC pipe in the elbows at any angle. The marble is smaller than the split PVC, so it will just pass through the elbow.
jmartel
#4 posted 06-15-2014 06:27 PM
You can also get it in long and short radius elbows.
And just cut off the flange portions.
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1618 days
#5 posted 06-15-2014 11:50 PM
When I made one for my daughter years ago, I used oak corner molding set as a “v” for the marbles to roll in. No lift, just an escapement at the top to release the marbles one at a time.
-- Malcolm Laurel - http://MalcolmLaurel.com
chetrog
#6 posted 06-16-2014 02:18 AM
Thanks for the suggestions guys. I found some electrical conduit that will work for the sweeps but there pretty big. I might use a few 45’s with a short piece of pipe. Still don’t know what im gonna do for a lift.. Thanks again
MrRon
#7 posted 06-16-2014 10:35 PM
Check the toy section at Walmart or Toys-R-Us. You may be able to find a toy that has some kind of lift. One has to use some imagination to find what can work and just improvise, adapt. If you use split PVC pipe, you can use a heat gun to get gradual turns and twists.
TopamaxSurvivor
18267 posts in 3671 days
#8 posted 06-16-2014 10:40 PM
There are lots of different styles of marble pumps used on marble machines. Quite a few have been posted here and on U-tube.
chetrog
#9 posted 06-17-2014 02:34 AM
”. If you use split PVC pipe, you can use a heat gun to get gradual turns and twists.”
- MrRon
Would it work if i ripped the pvc in half first? or do you think I should bend it first then cut the angles. I have never used a heat gun before, but I might have to buy one tomorrow.
Checking u-tube for pumps rite now. Thanks again everyone.
TopamaxSurvivor
#10 posted 06-17-2014 06:55 AM
BEnding PVC can be a bit tricky. When it gets to the right temp it works pretty well. A little hotter and it crimps. I would do it in the round, then rip.
MrRon
#11 posted 06-17-2014 10:32 PM
Rip the PVC first then apply heat gradually. I use a HF heat gun; cost <$10.
