Craftsman 22124 table saw motor problems
Forum topic by jmyeargin posted 06-14-2014 05:00 PM 849 views 0 times favorited 1 reply Add to Favorites Watch
View jmyeargin's profile
jmyeargin
1 post in 1312 days
06-14-2014 05:00 PM
I have a craftsman 22124 and the motor only seems to have about half the power that it should. I can make the blade stop with 3/4 pine if I push it through a little fast. I checked all the connections to make sure they are tichgt and not showing any signs of arcing or wear. i chacked the capacitors and the run capacitor had pretty much melted, so i replaced it and i am having the same problem. Any ideas?? i am to the point that i think i am going to have to replace the motor, but i would like to exhast all options before i swing 400 bucks for a motor.
1 reply so far
View knotscott's profile
knotscott
7817 posts in 3245 days
#1 posted 06-14-2014 05:06 PM
Double check both caps again just to be sure, b/c it sounds like a cap issue (it’s not common to actual smoke an induction motor totally). Be sure the belts are tensioned and seated properly. I know it’s a TEFC motor, but I’d blow out any dust just in case. I’d also check bearings. AFAIK, that motor is has a standard NEMA 56 frame, so you shouldn’t have to spend $400 even if it needs to be replaced ….any suitable motor with the same frame should work.
