can i use?
Forum topic by whitesferry posted 06-14-2014 01:38 AM 1048 views 0 times favorited 6 replies Add to Favorites Watch
View whitesferry's profile
whitesferry
17 posts in 1577 days
06-14-2014 01:38 AM
i was going to start with danish oil a few coats .then sand and then can i ? use zar 117 maple honey or must i only use mineral spirits ? n then the zar it’s ambrosia maple table top then minwax wipe on poly ? what does every one think im not sure these products are compatable . thanks alex
View bondogaposis's profile
bondogaposis
4931 posts in 2473 days
#1 posted 06-14-2014 01:45 AM
As always test on some scraps to get the finish that you like and avoid mishaps.
-- Bondo Gaposis
View Picken5's profile
Picken5
261 posts in 2813 days
#2 posted 06-14-2014 03:15 AM
I’ve used wipe on poly directly over Danish oil and it turned out great. Of course, you have to make sure the Danish oil is completely dry — typically 72 hours and sometimes more depending on humidity and the type of wood. And, like Bondo said — test on some scraps first.
-- Howard - "Time spent making sawdust is not deducted from one's lifetime." - old Scottish proverb
16276 posts in 4340 days
#3 posted 06-14-2014 01:25 PM
Using poly over Danish oil is no problem, but I’m not sure about applying stain in between as you propose. I’ve never tried it, but I would think the Danish oil would tend to keep the stain from soaking in. A better bet would be to mix the stain and Danish oil to get the color you want. You can even buy pre-colored Danish oil in a variety of shades.
View ChefHDAN's profile
ChefHDAN
1123 posts in 2971 days
#4 posted 06-14-2014 01:37 PM
+1 Charlie, I actually tried once to darken a project after oil and the stain just wiped right of
whitesferry
#5 posted 06-14-2014 06:05 PM
thanks for all your help folks im going to utilize all ur information thus far . i think danish oil then poly will be fine but will the poly be durable enough to take drink spills or cups it’s going to be a coffee table but i dont wanna ruin it my self im ok with it, but kids will be kids sooner or later they’ll set or spill something on it . or do you id be fine with several coats of the minwax wipe on poly high gloss 4 5 coats ? to protect it better
ChefHDAN
#6 posted 06-14-2014 10:08 PM
white, I’ve got three kids and I’ve put poly on everything and some pieces after 10+ years are still doing fine, it essentially plastic coats the surface so there are no coasters required, one of my daughters got nail polish all over a refinished QS white oak table in the kitchen & it came right off.
