| Forum topic by DAN | posted 307 days ago | 641 views | 0 times favorited | 18 replies | ![]() |
307 days ago |
Topic tags/keywords: question tip oak bandsaw carving tool lathe planer drill-driver chisel drill press clamp plane sander tablesaw I have a frame to make for the stained glass window business ... Beauverre Riordan Studios quarter sawn white oak x 1.25 inch square stock question is what joint should I use to attach the radius corners to straight sides ? .... and how should I orient the grain ? diagonal ? .... see corner detail sketch below. My thoughts are a bridal joint … anyone got a better idea ? I’m also thinking about laminating three pieces of 7/16 stock for the corner pieces to strengthen the radius … anyone have a better idea ? should I use 4 layers ? any better ideas ? Window glass is a very heavily made … Tiffany style leaded and multiple layed high-end glass . It will hang, by chains and eye bolts in the window of their showroom … both sides will be line-of-sight finished. Excuse the photo … it was taken with window on a light table…. had to distort the photos in Photoshop to allow for the perspective tapering and is two photos seamed together, as I ‘m not tall enough to get the entire piece in the view finder at one time. Design of frame inspired by works of Alphonse Mucha ... ![]() ![]() ![]() -- work from your heart and your spirit will live forever |
307 days ago |
I’m no expert, but what about a bridle joint with a dowel pin through on each end of the radius? Might make a nice accent with a dark wood. -- Rick |
307 days ago |
I would laminate the strips right into the straights, and join as a tongue and groove. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
307 days ago |
I would use my domino to join it. to get the grain to flow, I would cut the peice you are going to use and domino them together, then cut the curve. Instead of dominos, you could use dowls or mortice and tennons Callum -- For wood working podcasts with a twist check out http://thetimberkid.com/ |
307 days ago |
I would orient the grain diagonally and use a spline joint or mortise and tenon with or without pins. The pins could be decorative or functional. Functional would be better. Round or square pins depending on design preferences. -- Oldworld, Fair Oaks, Ca |
307 days ago |
Dan – Strength is paramount here, you also need stability. I think that you need to use laminated wood throughout this project. Bending such a tight radius with oak will require thin laminates – you could pre-steam thicker laminates. Important thing (appearance) to cut, number and sequence the laminates. I would make the structure in 4 sections, allowing minor X,Y adjustment for size. Jointing the structure – I would think long bridal joints should be sufficient, but you you could make locking bridal joints if there is an extreme of pressure present. Do not forget the appearance of the joint, where it is going to be viewed from. -- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (http://www.poydatjatuolit.fi) |
307 days ago |
whats a bridal joint? |
307 days ago |
I dido Tony’s remarks. I think that would give you the best frame for looks and stability. -- Jerry--A man can never have enough tools or clamps |
307 days ago |
Hi Dan, I’m with rickf16, |
306 days ago |
Some more thoughts and considerations on the seemingly simple question (I hope you do not mind Dan). I think there is a fundamental flaw with the idea proposed in the drawing by bentlylj. This piece would have 8 joints, thus doubling the chance of a joint failure, vs the proposal I made (not that my proposal is the only or the necessarily the correct solution). in addition as you can see from the sketch below, the tenon does not fully fit with the curved part, therefore leaving an area, that must be plugged/filled. you are also limiting the length of the joint, whereas in my proposal you could make each joint several inches long, without a problem, thus increasing the strength of the joint You also have to consider the size and weight of the glass panel being supported (37” x 28” x ?” thick) it is going to be heavy and probably very expensive and irreplaceable. You also have to consider how the whole assembly (Glass and frame) is going to be supported when finished as this will effect the stress points and the way the frame reacts. I hope this clears up my thoughts on the problem -- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (http://www.poydatjatuolit.fi) |
306 days ago |
You make the joint easily with the pieces then after fitting them, cut the radius with your router. This way it will all blend perfectly. -- making sawdust.... |
306 days ago |
Tony, You are correct about the tenon, that’s why I suggested making the tongues on the curved sections. |
306 days ago |
I also looked at the reverse sollution you mentioned, but you then going to have a “Short Grain” problem on the tenons. However loose tennons would solve that problem (The timberkid). Number of joints – you are correct the number of joints if made correctly should not matter, but sometimes things go unseen during manufacturing, therfore twice as many joints, twice the chance of failure of one of the joints. -- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (http://www.poydatjatuolit.fi) |
306 days ago |
I’m no expert with short grain situations, but I doubt that a short grain situation on a frame this size wouldl have an adverse affect. I could be wrong. ”things go unseen during manufacturing” |
306 days ago |
I knew this was brain teaser …. I’ve been thinking about it for a couple days myself figure it would be a good question to ask in the forum section … I’m still not positive on how I’ll end up doing this thing. -- work from your heart and your spirit will live forever |
306 days ago |
Hi Dan; You could always use edge banded plywood. Just a thought. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
305 days ago |
Hello Lee … plywood crossed my mind, but doesn’t really fit the requirement. Forgot to mention in my topic that the piece is to look really old or antique when done I’m using ideas from both Bently and Tony. I adjusted my design a bit, making the cross section 1 1/4 on the face sides and 1 7/8 on the side cross section. I’m thinking if the finished joint doesn’t look strong enough I’ll run a 1/8 dia x 6 inch brass rod down the center of the corners. ![]() ![]() -- work from your heart and your spirit will live forever |
305 days ago |
I would have made the corners as a bentwood lamination, with the t&g turned 90 degrees to mate with the laminated sides. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
305 days ago |
I have not had much experience with bent lamination. Only a couple projects. In the photo above, the corners as shown only has about 2 man hours of labor. The mortises are about 11/16 wide and 1 & 1/2 deep… that leaves about 1/2 inch stock for the shoulders. Looks pretty strong … -- work from your heart and your spirit will live forever |
| Forum | Topics |
Woodworking Skill Share
2920 |
3945 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
