Is it true that there is a "Cab" Alder and a "Cabinet" grade Alder?
Forum topic by BobMaty posted 06-13-2014 06:59 PM 831 views 0 times favorited 2 replies Add to Favorites Watch
View BobMaty's profile
BobMaty
1 post in 1348 days
06-13-2014 06:59 PM
...and that they are two different grades of lumber?
2 replies so far
View LiveEdge's profile
LiveEdge
571 posts in 1525 days
#1 posted 06-13-2014 09:09 PM
We have lots of alder here in Oregon and at the hardwood seller I use. I’ve never heard of “cab” alder. I’d say either that is “cabinet” grade or could it be “SAB” for “select and better”?
View ,'s profile
2387 posts in 3451 days
#2 posted 06-14-2014 02:11 AM
In our area Alder is used a lot. We have knotty alder and select or clear alder. Knotty alder is about 1/2 what the select alder cost. I suspect that the difference you are referring to in OP is just the selection process, the more expensive version will be cleaner with less knots.
We actually use Alder a lot. Mainly because the builders tend to spec out Alder for the custom cabinets.
Alder is also very easy to stain if done correctly while achieving very even results.
