Woodpeckers Flat Bars
« back to Hand Tools forum
Forum topic by mramseyISU posted 06-13-2014 04:54 PM 3985 views 0 times favorited 18 replies Add to Favorites Watch
View mramseyISU's profile
mramseyISU
533 posts in 1509 days
06-13-2014 04:54 PM
Topic tags/keywords: clamp
Anybody else seen these flat bars Woodpeckers is peddling?
http://www.woodpeck.com/flatbars.html
Looks like a fancy overpriced set of clamping cauls. At first I thought they looked like a great idea but the more I stared a them the more I wondered why couldn’t you just buy a hunk of Unistrut and cut it to the length you want and be done with it. So I think I’m going to buy some unistrut tonight and make my own.
-- Trust me I'm an engineer.
18 replies so far
View Loren's profile
10252 posts in 3612 days
#1 posted 06-13-2014 05:08 PM
You might consider, for the money, investing in a pair of 8”
deep throat clamps.
I never used cauls and seldom used bicuits or anything like
that in the past. Sometimes I would hammer a waxed wedge in
under a pipe clamp over an area where a board was bulging.
Now I have a plano clamp which makes all this clamping
panels easier.
View pintodeluxe's profile
pintodeluxe
5620 posts in 2777 days
#2 posted 06-13-2014 05:19 PM
Yes, they look like clamping cauls to me. I use hardwood 2×2’s that have a slight crown. I set the cauls convex side against the panel to be glued up. That way clamps placed at the edge of the cauls can exert force evenly across the panel. I put duct tape on the side of the caul that will contact the panel to keep it from sticking to the panel. Works great.
View MrRon's profile
MrRon
4710 posts in 3207 days
#3 posted 06-13-2014 06:32 PM
I’m sure the Woodpecker bars are not crowned, but simply a 1×1-1/4×24 or 36” piece of 6061-T651 aluminum bar. The retail price from a metals supplier is $15.26 for a 24” long bar and $21.48 for a 36” long bar. Multiply that by 2 for two bars and the material costs $30.52 and $42.96 for the bars. Of course they get the bars at wholesale. The price sounds fair as the raw material constitutes a large % of the overall cost. If you wanted to make your own, you could buy the bars yourself at http://www.onlinemetals.com/ and save half.
View Ocelot's profile
Ocelot
1956 posts in 2602 days
#4 posted 06-13-2014 06:56 PM
This is interesting info. Thanks MrRon. We’ve got a mechanical engineer here, but I wouldn’t want waste his time asking about materials. It looks like 6061 is the right stuff at the right price.
I wonder if Woodpeck machines theirs flat or just uses what the supplier sends.
View JohnChung's profile
JohnChung
407 posts in 2038 days
#5 posted 06-13-2014 07:01 PM
I won’t buy them. Easy fabricated with scrap wood.
MrRon
#6 posted 06-14-2014 08:15 PM
Ocelet; I can’t be positively sure, but I work with these sizes of aluminum all the time and find they are as straight as it is possible as shipped from the supplier. If you want to make your own, get some 1×1x1/8 steel angle and drill holes in the ends for bolts and nuts. You will need an assortment of hole spacings because you want to place the bolts as close to the edges of the wood you are clamping. Too far apart and you will end up with bowed members
mramseyISU
#7 posted 06-14-2014 08:25 PM
Ron; that’s exactly why I think buying a 10’ stick of unistrut would be the way to go here. It’s pretty rigid as is and you’ve got the holes already. One 10’ chunk goes for about $15-$20 and you’d have enough to make a pair of 2’ bars out of it with a bit left over.
View ducky911's profile
ducky911
237 posts in 2753 days
#8 posted 06-14-2014 10:01 PM
why not put mult. holes so the long ones could do any width??
When I have felt rich and bought woodpecker stuff I have been happy…really like using my small t square
View Matt Rogers's profile
Matt Rogers
109 posts in 1934 days
#9 posted 06-15-2014 01:57 AM
Unistrut is a great idea. I have some long pieces that have holes every few inches and got them used for cheap. They are seem to be very stiff. I also have a set of wooden cauls – 2×3 ash with one set dead flat and the other crowned. I place the flat ones down on the bench and lay out the material, then sandwich the panel with the curved ones after the clamps are lightly tightened.
-- Matt Rogers, http://www.cleanairwoodworks.com and http://www.cleanairyurts.com
MrRon
#10 posted 06-15-2014 07:31 PM
“Ron; that s exactly why I think buying a 10 stick of unistrut would be the way to go here. It s pretty rigid as is and you ve got the holes already. One 10 chunk goes for about $15-$20 and you d have enough to make a pair of 2 bars out of it with a bit left over. ”
- mramseyISU
I didn’t think unistrut would be strong enough, so I suggested solid angle.
View Gene Howe's profile (online now)
Gene Howe
10350 posts in 3392 days
#11 posted 06-15-2014 10:21 PM
I bought 20’ of Unistrut and made several pair of clamps for face to face laminations, and to keep edge glued panels even.
I have only one complaint. They are heavier than he!!.
View poopiekat's profile
poopiekat
4349 posts in 3698 days
#12 posted 06-15-2014 11:23 PM
And don’t forget, with Uni-strut you can use those spring-loaded, captive nuts for quick assembly with threaded knobs. You can put something together really fast, using 5/16” or 3/8” hardware. Perfect for keeping large glue-ups completely flat.
A perfect fastener for fixtures like Gene Howe made above.
View Manitario's profile
Manitario
2629 posts in 2847 days
#13 posted 06-15-2014 11:32 PM
I use cutoffs of plywood with packing tape over it so the glue doesn’t stick and a couple of F-clamps…
mramseyISU
#14 posted 06-16-2014 02:56 AM
That’s what I’m talking about Gene. Do you have any problems with it splaying out on the lips?
View camps764's profile
camps764
867 posts in 2324 days
#15 posted 06-16-2014 03:11 AM
never would have bought them from wood pecker, but I will be giving my plumber buddy a call to see if he’s got any scrap unistrut laying around his shop :)
-- Steve
