how to clean spray nozzles?
Forum topic by JesseTutt posted 06-12-2014 02:18 PM 5177 views 0 times favorited 11 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2134 days
06-12-2014 02:18 PM
Topic tags/keywords: spray adhesive nozzle cleaning nozzle question
It seems that I am forever grabbing that can of temporary spray adhesive to attach a pattern to a piece of wood and finding that the plastic nozzle is clogged.
What method(s) have you found to clean the plastic nozzle on a can of spray adhesive?
(I was not sure whicch forum to post this in)
11 replies so far
View longgone's profile
longgone
5688 posts in 3332 days
#1 posted 06-12-2014 02:34 PM
Very simple…I turn the can upside down and spray until the glue stops coming out and then clean any residue on the nozzle tip with a bit of acetone and a paper towel or rag. This has never failed and I have been using spray adhesives for many years
JesseTutt
#2 posted 06-12-2014 03:44 PM
Greg: you are correct. I normally do this, but sometimes when I come back to use the spray the nozzle is clogged up. What do I do in that case?
View TheFridge's profile
TheFridge
9606 posts in 1510 days
#3 posted 06-12-2014 03:51 PM
Pull out the hammer.
4999 posts in 2517 days
#4 posted 06-12-2014 04:00 PM
I keep a torch tip cleaner in my shop tool box for such stuff. This amounts to a $3 tool that has a bunch of really small round shafts in different sizes that are serrated to clean the orifices on torches. But I use the upside down trick, so don’t really have much problem with it.
View Finisherman's profile
Finisherman
227 posts in 1873 days
#5 posted 06-12-2014 05:16 PM
Soak the nozzle in lacquer thinner or acetone and then use a fine toothpick or a needle to clean out the nozzle’s orifice. As others have said, make it a habit to turn the can upside down and spray until only the propellant gas comes out. I do this all the time and I never have a problem. If worse comes to worst, you can always swap the clogged nozzle for one off of an empty aerosol can.
View Knothead62's profile
Knothead62
2584 posts in 2985 days
#6 posted 06-12-2014 07:29 PM
What Finsherman said.
View DaleM's profile
DaleM
958 posts in 3408 days
#7 posted 06-12-2014 09:39 PM
Yep, same as above. I just used lacquer thinner today on a spray glue nozzle. It worked great. I didn’t even have to remove it and soak it, just used a brush dipped in the thinner to clean off the nozzle.
-- Dale Manning, Carthage, NY
View strandedpirate's profile
strandedpirate
8 posts in 1475 days
#8 posted 06-12-2014 11:31 PM
Cheap carb cleaner with a straw attached always works for me.
View Woodendeavor's profile
Woodendeavor
276 posts in 2630 days
#9 posted 06-13-2014 01:47 AM
I have a small jar of lacquer thinner, putt the spray tip off the can and toss it into the jar until next time. Have not had any problems
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#10 posted 06-13-2014 03:27 AM
I like spray adhesive for some things, but for template patterns I use carpet tape. It is double sided tape available in the tile / flooring section of Lowes.
View Redoak49's profile
Redoak49
3281 posts in 2012 days
#11 posted 06-14-2014 01:13 AM
I frequently use 3M spray adhesive and the nozzles get clogged. Turning them upside down to spray wastes a lot of adhesive. I clean the nozzles off as good as I can but when they good really bad I replace them. I found someone on ebay that sells replacement nozzles and it has been well worth it.
