How to accomplish the decorative part
Forum topic by Vandy posted 06-11-2014 03:52 PM 932 views 0 times favorited 7 replies Add to Favorites Watch
View Vandy's profile
Vandy
10 posts in 1890 days
06-11-2014 03:52 PM
Topic tags/keywords: outdoor patio furniture router molding design question teak shaping
http://www.restorationhardware.com/catalog/product/product.jsp?productId=prod3070602&categoryId=search!
I was thinking maybe it was a bull-nose router bit; however I can’t find one with the same profile. In the picture, it seems the molding part is two small rounds surrounding the larger Bull-nose round.
Any other thoughts to how the decorative parts are built, most importantly along the bottom left section I highlighted
I am trying to replicate this chair for my house
(If you click on the link, you can actually zoom in on the image at the website for a closer look)
Cheers
7 replies so far
View bondogaposis's profile
bondogaposis
4601 posts in 2256 days
#1 posted 06-11-2014 04:33 PM
On the left side I believe it was made with two passes of a point cutting round over bit, like this. On the right, that picture is not detailed enough to figure out exactly how it was made but likely a custom made shaper bit, that the the factory uses. It could be approximated by using several different router bits in combination. It will take some experimentation to get the look you want.
-- Bondo Gaposis
Vandy
#2 posted 06-12-2014 02:28 AM
Yeah okay great, I’ll give that a try. thanks for the response.
View TheFridge's profile
TheFridge
8882 posts in 1391 days
#3 posted 06-12-2014 02:44 AM
Check out woodgears.ca. He can make a semi circle moulding with a tilting router lift. What was said above is prob much easier, but Matthias from woodgears.ca shows way to make much more complicated mouldings with a homemade tilting router lift and some cheap router bits. He’s got some great info.
View sras's profile
sras
4747 posts in 3034 days
#4 posted 06-12-2014 02:46 AM
As a far fetched suggestion, you can get close with what you have and hand work the difference. For instance, a few cuts on a table saw will remove most of the unwanted material…
View JAAune's profile
JAAune
1780 posts in 2222 days
#5 posted 06-12-2014 05:17 AM
Moldings like that are actually pretty easy to do if milled in separate pieces then glued together. Because of the deep contours, it’s next to impossible for people to tell they aren’t milled from a solid block so long as the grain is somewhat similar.
Just be careful with the glue up if using that method. You want all squeeze out going to the back and not towards the profile.
View Marcus's profile
Marcus
1163 posts in 1925 days
#6 posted 06-12-2014 10:30 AM
I was going to suggest what JAA did…if you cut these in pieces and then glue up, life will be much easier.
View Buckethead's profile
Buckethead
3194 posts in 1774 days
#7 posted 06-12-2014 11:41 AM
+3
Also… A beading plane or scraper would get the job done. If you’re into that sort of thing. ;-)
-- Support woodworking hand models. Buy me a sawstop.
