20" planer tune up help
Forum topic by giser3546 posted 06-11-2014 02:47 PM 1455 views 0 times favorited 23 replies Add to Favorites Watch
View giser3546's profile
giser3546
179 posts in 1497 days
06-11-2014 02:47 PM
Through an incomprehensible amount of just blind luck I managed to become the new owner of a 20” Sunhill 220V 5 hp planer for the convenient price of FREE. It appears to be in good shape, no rust anywhere and I was told ”... it will run but needs some work”. My problem is I know little if any about working on these things. I’m aware Sunhill no longer exists but I have been told they are similar to all the other Asian made machines. Where would be a good place to start on tuning this thing up and getting it to run as well as it can? What are the potential problems I should look for?
Along with the planer I was given a bundle of 17 blades. All are in varying states of disrepair but I mostly plan on using this for shaping rough sawn stock. My final finished surface will be done with smoother and scraper plane.
-- "If you wait for it to rain, It will"
23 replies so far
View Buckethead's profile
Buckethead
3194 posts in 1894 days
#1 posted 06-11-2014 03:22 PM
Others will be able to steer you in the right direction regarding diagnosing and repairing, but as for the blades, they need to be sharp. Regardless what type of finish you want to achieve with the machine, sharp blades will minimize tear out and make the machine operate more smoothly.
I also believe your machine is fairly common, with replacement parts readily available. Posting photos of the insides
As well as the outside will garner responses much faster, and allow those with knowledge to help you along.
-- Support woodworking hand models. Buy me a sawstop.
giser3546
#2 posted 06-11-2014 03:34 PM
Messed up camera phone and a dead camera batter have held me up… pictures will be posted soon.
View Loren's profile
10476 posts in 3673 days
#3 posted 06-11-2014 03:58 PM
They are sort of still around… mainly distributing the new imported
Oliver badged machines I think. ph: 800-929-4321
I don’t recommend opening a gear box but you may want to
drain and change the oil. Planers are robust machines and
the feedworks is the part that’s most vulnerable to wear,
though most any cast iron planer would take a lot of use to
wear out the feedworks.
Mostly you should focus on cleaning and waxing the bed, getting
sharp knives accurately installed. Then you can test and
see what it will do.
giser3546
#4 posted 06-11-2014 04:06 PM
I did receive a blade guide (I’m assuming thats what its called), a small metal rod with forked brackets on either end. He mentioned it was for setting the blades and gave me a quick lesson on how to use it but didn’t go into detail.
#5 posted 06-11-2014 04:11 PM
Often there are grub screws in the cutterhead which
bear against the back edge of the knife. You set the
knife in there, put your gauge on top and assess where
the knife should be higher or lower. Then remove the
knife, adjust the grub screws and check again.
Sometimes there are springs and you push the knife
down with the setting jig and tighten the gib screws
with your other hand.
Sometimes there is nothing and the knife is held in place
by the gibs only so you tighten them a little so the
knife can still slip a bit and go from there. This is the
most annoying style of cutterhead but you’ll manage.
giser3546
#6 posted 06-11-2014 05:55 PM
Would there be any hope of finding some kind of owners manual for this?
View bowedcurly's profile
bowedcurly
519 posts in 1754 days
#7 posted 06-11-2014 06:05 PM
looks the same as the older Grizzly and powermatic planers they all have the same build, made is Indochina somewhere
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
View OldWrangler's profile
OldWrangler
731 posts in 1620 days
#8 posted 06-11-2014 06:52 PM
Seems to me that when I was shopping for a planer, I ran across a Sunhill, new being sold by Amazon (I think). I’m sure it was a 12-13” and it wasn’t cheap, like $500.That might be a place to start. They may tell where it will be shipped from and who the distributor is. Find the distributor and maybe they can supply parts and owners manual. Blades will be no problem either buying new or getting sharpened.
You are indeed lucky for getting this machine and whatever you have to put into it will be worth it. 20” planers are hard to come unless you have really deep pockets….they are expensive but they will do so many more things that a 13” can’t. Good luck.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
giser3546
#9 posted 06-11-2014 07:32 PM
Thanks, Im reading over the 20” grizzly manual right now and it appears similar at least at a glance. At the very least I’ll be able to get an idea of maintenance
Shawn Masterson
1325 posts in 1974 days
#10 posted 06-11-2014 08:46 PM
Just a heads up I have a 20” jet knock off. I just picked up an extra set of HSS knives from my sharpening guy. They are Freud and a set of 3 was $125+ tax. Around here ( South Bend IN )I can get HSS knives sharpened for
$ .40 an inch. The carbide set is $ .80 an inch and usually next day turnaround.
OldWrangler
#11 posted 06-12-2014 01:29 PM
In looking up this machine, I found that it takes a set of 4 20” blades and one dealer sells the set for $329. I would definitely get the old ones sharpened.; Still you got a bargain.
giser3546
#12 posted 06-13-2014 02:25 AM
Attempted to take a few pictures of the planer, didn’t go well considering this was the only one worth posting. But this happens to be the thing that’s confusing me at the moment. I’ve read the manual for the Jet 20” and the Grizzly 20” and they both mention filling the gear box with 90 weight gear oil, this one doesn’t even seem designed to hold any liquid. I’m sure I need to clean them but what then? Grease? Also one of the chains is tight the other (the lower one) is quite loose. Should they be tight?
giser3546
#13 posted 06-13-2014 02:49 AM
More pictures
View ,'s profile
2387 posts in 3572 days
#14 posted 06-13-2014 02:52 AM
Looks like you got yourself a decent planer there. Congrats.
giser3546
#15 posted 06-13-2014 03:37 AM
Realized my mistake with the location of the oil bath…
