dead flat finish
Forum topic by chargerdon posted 06-11-2014 03:04 AM 1317 views 0 times favorited 6 replies Add to Favorites Watch
View chargerdon's profile
chargerdon
3 posts in 1359 days
06-11-2014 03:04 AM
I have finish my project Farm Table and very disappointed in the shine. I used Watco Dark Walnut and it turned out great. I didn’t build it just the finish. I was hoping for a dead flat shine like the old rustic look. Hate to put a top coat of Poly and then it is a satin at best. When I was a apprentice painter (50 YRS ago) there was a flating oil if I remember right. None of the major paint companys knows or can help, Any suggestions ? Sure need some help. Thanks
-- Don in Calif.
View Yonak's profile
Yonak
986 posts in 1429 days
#1 posted 06-11-2014 04:05 AM
This isn’t a solution .. just the opposite, in fact. I bought some Zar polyurethane that was advertised as flat, but it wasn’t, so I would advise against that route.
View dawsonbob's profile
dawsonbob
2742 posts in 1664 days
#2 posted 06-11-2014 04:13 AM
Don
You might want to ask the paint companies about a “flattening”¬†agent. Yes, it used to be called flatting, but recently I’ve only seen it called “flattening.”
Go Chargers!
Bobby in San Diego.
-- Mistakes are what pave the road to perfection
View Woodknack's profile
Woodknack
11139 posts in 2288 days
#3 posted 06-11-2014 03:35 PM
Rub it out with steel wool and a dab of wax.
-- http://thewoodknack.blogspot.com/
View Mario's profile
Mario
160 posts in 3305 days
#4 posted 06-11-2014 03:48 PM
You might want to use lacquer instead, try 4 or 5 coats with any hard transparent lacquer, rub out the finish and spray your last coat with flat lacquer. This way your finish will be clear and dead flat. When living in Texas we would drive down to Mexico and bought flat lacquer from the Sayer Lack store over there, worked every time.
View oldnovice's profile
oldnovice
6554 posts in 3276 days
#5 posted 06-11-2014 07:28 PM
I’m with Rick M. on this one as I have done this myself!
chargerdon
#6 posted 06-12-2014 04:01 AM
I knew I could get there using Lac. but it is a very hard finish that scratches easy. If I can I would like to stay with the softer type
I’m going to do a small side board next, so I think I will try a different system. any suggestions?? AND YES GO CHARGERS
-- Don in Calif.
