Unruly Cherry Boards
Forum topic by BuyoMasilla posted 06-10-2014 11:27 PM 941 views 0 times favorited 4 replies Add to Favorites Watch
View BuyoMasilla's profile
BuyoMasilla
104 posts in 2452 days
06-10-2014 11:27 PM
Topic tags/keywords: finishing cherry
Hello
I picked up a cherry board and had the store, McBeath, resaw it for me. Cut it to size to do some “toe kicks” as I continue to work on finishing the living area of our home (tile and laminated floor have gone down and look pretty nice if i may say so myself). I’ve had the opportunity to put my WoodWorking tools to use in installing and triming the job. Whereas I used some figured cherry board I had in the garage for years for some of the trim work and was met with approval, a figured walnut was not approved and this last cherry board turned blotchy when the stain was applied. My wife has done and does all the finishing and got the other cherry to match. This last resawn board is not cooperating.
I indicated to her that this may be a problem with the grain being not consistent in its “pores” and I guess the sap wood and other wood also having different properties. I also said I’ve heard of “sealing” products to counteract this potential problem.
My main question is, is there a way to remove the stain that has gone in and then apply the sealant? A coat of minwax stain has been applied. If so, does the sealant goes on all the board or those areas prone to sucking up the stain? I’m going to try to upload some pictures. Thanks in advance for reading and any feedback.
Mario
-- Dreaming of the day I might joint two pieces of wood square..........
BuyoMasilla
#1 posted 06-10-2014 11:31 PM
View Ripthorn's profile
Ripthorn
1454 posts in 2889 days
#2 posted 06-10-2014 11:34 PM
Minwax stain is pigment based, so just a light sanding should get rid of the pigment particles that just sit on top of the wood.
BuyoMasilla
#3 posted 06-10-2014 11:40 PM
Posting the pictures was easier than I thought. Here’re some examples of the other cherry being used for trim, and a piano my wife refinished showing the main reason why I leave that work to her.
View b2rtch's profile
b2rtch
4847 posts in 2953 days
#4 posted 06-11-2014 12:27 PM
A LIGHT SANDING AND A GEL STAIN SHOULD SOLVE YOUR PROBLEM OR YOU COULD USE A WOOD CONDITIONER
http://www.minwax.com/wood-products/stains/minwax-gel-stain
http://www.minwax.com/wood-products/preparation/minwax-prestain-wood-conditioner
I THINK THAT OTHER BRANDS MIGHT BE BETTER THAN MINIWAX BUT MINIWAX IS OK
-- Bert
