Joints for box with 3/8" stock
« back to Joinery forum
Forum topic by docspencer posted 06-10-2014 09:28 PM 720 views 0 times favorited 5 replies Add to Favorites Watch
View docspencer's profile
docspencer
335 posts in 1818 days
06-10-2014 09:28 PM
I’m making a charging station for a phone, tablet, etc. The bottom is essentially a box which houses the multiple outlet the devices plug into. The top of the box is removable. I am using 3/8” stock for all the pieces. What I’m struggling with is how to join the sides and the bottom to each other. Seems too thin for either a straight up glue joint or dowels (or biscuits though I don’t own the tool). I’m open to any suggestions…..
5 replies so far
View firefighterontheside's profile (online now)
17226 posts in 1730 days
#1 posted 06-10-2014 09:31 PM
Miter and glue should hold. When you miter it the glue surface will increase. Box joints would be great but I have no experience with them though I need to and want to. Good luck.
View jmartel's profile
jmartel
7632 posts in 2023 days
#2 posted 06-10-2014 09:45 PM
Finger joints, box joints, dovetails, lock rabbets, glued mitre, splined miters, etc. Anything you want.
View Gene Howe's profile
Gene Howe
9929 posts in 3301 days
#3 posted 06-10-2014 09:47 PM
Dado for the bottom, miter the corners. If the bottom is solid, leave it unglued. If it’s ply, glue it.
If you are concerned about the corners, (I would be) put couple splines in them after the box is built.
Similar to the picture but imagine the frame is a box.
View The Box Whisperer's profile
The Box Whisperer
678 posts in 1943 days
#4 posted 06-10-2014 09:48 PM
everything jmartel said. Also, you could do a pinned rabbit, (or pinned dovetailed rabbit) if you can find small dowels. Lee Valley sells them.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
docspencer
#5 posted 06-10-2014 10:03 PM
Wow, some interesting and great ideas. Never tried any of these but if I can get past my fear of screwing it up they should be fun to try something new. Thanks.
