Designing Mobile Workbenches - Best Height?
Forum topic by Bionicjoe posted 06-10-2014 06:06 AM 1534 views 0 times favorited 19 replies Add to Favorites Watch
View Bionicjoe's profile
Bionicjoe
1 post in 1447 days
06-10-2014 06:06 AM
Topic tags/keywords: question
I just built my first mobile work table. It’s just an old cabinet from an entertainment center put on a stand & wheels. I built it 39” high & ultimately I want a series of benches and tool stands that are all the same height for uniformity & outfeed support.
My tablesaw & router table (bought from a guy who had built it) are both about 34.5”. I think that’s a bit low.
Is there a good standard height I should shoot for or just custom build to the height I like?
http://i.imgur.com/OF9Jb8O.jpg
19 replies so far
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2070 days
#1 posted 06-10-2014 10:18 AM
Ergonomics come down to the user. I general rule of is that you should be able to stand up straight, and rest your hand on the bench with a slight bend in the elbow. Also keep in mind you may want to add floor padding too. I am tall and I have back issues so mine are pretty tall at 42” Either way I think you have the best plan at having them all the same height.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View redSLED's profile
redSLED
790 posts in 1892 days
#2 posted 06-10-2014 12:43 PM
^ Like he said. Personal comfort choice. This becomes more of an issue if you do/anticipate doing repetitive work and/or you have back/joint pains.
I really liked the height using my buddy’s General cabinet table saw a while back which was 35” high. Since I currently use mostly power tools, I’ve made my workbench and other stand heights to outfeed on at 35” – feels right for me for most work I do so far.
View Gene Howe's profile
Gene Howe
10479 posts in 3428 days
#3 posted 06-10-2014 12:58 PM
I like my bench at the height that meets my knuckles as they hang loose at my side.
But, making it at a personalized height may not be the best for an outfeed table for the TS. Of course, you could put the TS on a platform.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2914 days
#4 posted 06-10-2014 01:09 PM
My height = 5’ 9”
34.5in is generally the average TS height when on a mobile base. Hard, but not impossible, to change this height. Same for average height on most jointers.
Workbenches are as stated above (personal preference). I am finding that a taller (~39in) bench is easier to work on for such things as belt sharpener, drill press, hand sanding, etc. There is LESS bending over and that conserves energy and is less tiring IMO.
BOTTOM LINE—I would plan on dedicating a workbench solely your preferred height, and then build “another” bench/table for your needed outfeed uses.
View Crank50's profile
Crank50
173 posts in 1576 days
#5 posted 06-10-2014 01:41 PM
If you use hand planes and some other hand tools you will probably want a lower height bench than a power tool bench. On the other hand, precision work will be more comfortable if it is up close.
I think a low bench with a bench top bench accessory makes a lot of sense.
But like everyone says, bench height is a personal preference first. I just wanted to point out that type of work makes a difference too.
View stefang's profile
stefang
15881 posts in 3334 days
#6 posted 06-10-2014 07:42 PM
I know a lot of woodworkers have their benches at 39” high and some as noted above, even higher. I am 5ft. 10-1/2” and I have a really bad back, but my bench is 34-1/2” high and it seems very comfortable to me when I’m hand planing. Any higher and most of the work is transferred to the upper body and you don’t get so good use of your back and legs, so it seems strange to me that so many folks my height are using so much higher benches these days. I do realise that certain tasks using power tools, like hand held routers for example, are easier to use on higher benches, but not necessarily for hand tools in my opinion.
Shawn Masterson
1325 posts in 1948 days
#7 posted 06-10-2014 09:17 PM
My PM 66 pretty much sets the height. With what it weighs I don’t want to try and raise it.
bandit571
20013 posts in 2683 days
#8 posted 06-10-2014 09:40 PM
Usually, my benches that I’ve built (3) are right to the bottomof my belt buckle. Seems to be about right for the stuff I do. Try it out, see where YOUR belt buckle is, measure down to the floor, height of bench top is….
HorizontalMike
#9 posted 06-10-2014 09:46 PM
Crank50: ”...I think a low bench with a bench top bench accessory makes a lot of sense….”
Now THAT sounds like a neat project for any and all. Why not. I have dog holes all over my 34-1/4in high workbench, that would be very useful for doweled legs of an add-on 6-8in added “upper bench” for high work. I’ll have to think about that for a bit, but that might come in handy once I delineate just what tasks would benefit from doing this… Hmm…
HorizontalMike
#10 posted 06-10-2014 09:50 PM
bandit571: ”...Usually, my benches that I’ve built (3) are right to the bottomof my belt buckle. Seems to be about right for the stuff I do. Try it out, see where YOUR belt buckle is, measure down to the floor, height of bench top is…….”
Whut! Yew kin steel see yo’ belt buckle?! Quit rubbin’ it in already!... Geez these young pups got gall! Where’d I put dat Bud anyway… ;-)
View AlanBienlein's profile
AlanBienlein
159 posts in 2674 days
#11 posted 06-10-2014 10:06 PM
Every flat surface in my shop from the table saw and all other machinery to the work bench and the mobile carts are the same height. This makes life so much easier and the shop less crowded.
bandit571
#12 posted 06-10-2014 10:16 PM
Sometimes, one needs a bit of Difference in the shop
Like when a test fit before a glue up?
View moke's profile
moke
1175 posts in 2776 days
#13 posted 06-11-2014 05:26 PM
I have three mobile benches, two at 39” and one at 20”. The 20” is a cabinet assembly table that nestles inside one of the 39’s. I don’t know why I settled in on the 39 hieght but it seems very comfortable.
I might suggest that you look into double-lock castors. They lock both the roller and the swivel. Without a swivel lock they move to much to really be a good surface to work on. You really only need two double lock castors, and the other side put on the non swiveling. I makes for a great and stable work surface. If you want something even more stable, install two barrel clamps, one on each side. Install them so they contact the floor ( similar to the ones in a Kreg drilling jig).
Mike
-- Mike
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#14 posted 06-11-2014 05:43 PM
Outfeed supports need to align perfectly with the tablesaw. If not, it will bobble the cut (especially ripping bevels). That is the reason I made a dedicated outfeed support that adjusts with threaded table leg feet. Then I made a separate rolling workbench at a comfortable height. If space is a concern, you can make a low rolling cart for under the wing of your tablesaw. I sit on a rolling stool to use my cart for sanding, detail routing etc.
View Yonak's profile
Yonak
986 posts in 1521 days
#15 posted 06-11-2014 06:00 PM
I agree with some others. All of my movable working carts, stationary work benches, table saw, jointer, planer, etc. are at the same height for easy material transfer and for infeed and outfeed supports.
