Eight Inch Joiner Fever!
Forum topic by MT_Stringer posted 06-10-2014 04:20 AM 1092 views 0 times favorited 14 replies Add to Favorites Watch
View MT_Stringer's profile (online now)
MT_Stringer
3134 posts in 3106 days
06-10-2014 04:20 AM
Topic tags/keywords: poplar
Today, for the first time, I wished I had an eight inch joiner instead of a six. Several of the 4/4 rough poplar boards I had bought to build cabinet face frames were 6 inches or wider. :-(
I guess I will just have to get over it because I really don’t have the room for an eight incher. Sure would be nice though.
To get around the 6 inch limitation, I jointed a smooth edge on the wide pieces, then ripped a 3 1/4 inch piece out of a couple and a two inch wide piece from another two pieces. One board was just a little wider than the cutter head so I used a hand plane to smooth it out.
Still, an 8 incher would be nice. Hey, a guy can dream, can’t he? :-)
Oh well. Onward and upward.
14 replies so far
9774 posts in 3523 days
#1 posted 06-10-2014 04:31 AM
You can flip a wide board around and, using the rabbeting
ledge for support, surface up to 12” on a 6” jointer. It
will tend to be a little off and require some work with
hand planes to get the face flat enough to feed through
a planer and get a suitable board for cabinetmaking. Twist
is really the most important thing to get out of hardwoods
over 3/4” thick. The planer won’t push a cupped oak
board flat the way it will on pine, so the important thing
is to joint the surface opposite the planer cutterhead
so it rides free of twist. The planer will make the other
side pretty flat, then flip the board and plane the jointed
side. From there, assess and correct problems after
letting the board move overnight with a hand plane and
the planer.
MT_Stringer
#2 posted 06-10-2014 04:50 AM
Thanks Loren. I do have a planer sled that I have used in the past. For example, say the leftover portion is an inch or so that didn’t get jointed. I place the jointed portion of the board face down on the sled and let the rough portion stick over the side of the sled. After planing the side smooth, I flip it over and run it through the planer to remove the portion that had not been jointed.
View TheFridge's profile
TheFridge
8672 posts in 1361 days
#3 posted 06-10-2014 04:52 AM
The only problem I see is that you are drinking a diet drink that doesn’t have great taste and 28 flavors.
#DietDrPepperTastesMoreLikeRegularDrPepper
MT_Stringer
#4 posted 06-10-2014 04:59 AM
Heh heh, I hit the DP ever so often. :-)
View jonah's profile
jonah
1524 posts in 3174 days
#5 posted 06-10-2014 10:48 AM
If you’re making face frames, doesn’t that mean lots of narrow pieces anyway? Why not just rip each board to < 6 inches and then joint them separately?
MT_Stringer
#6 posted 06-10-2014 12:50 PM
Some parts are 3 inches. Others are 2, and some are 1 1/2. I want to use as much as possible from each board. It’ll work.
View bowedcurly's profile
bowedcurly
519 posts in 1604 days
#7 posted 06-10-2014 01:01 PM
sounds good to me, Ihit tha Pepper to once inawhile
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
View dbhost's profile
dbhost
5686 posts in 3107 days
#8 posted 06-10-2014 01:08 PM
FWIW, I ran smack into the jointer width problem myself last night. Much of my stock is 8+ ” wide. So even an 8” jointer would be too narrow… Solved it straight away with a planer jointing sled. It’s a bit ackward starting stock through the planer, but it works well enough I almost, but not quite, wonder why I bother with a jointer…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View johnhutchinson's profile
johnhutchinson
1243 posts in 1504 days
#9 posted 06-10-2014 01:35 PM
Just like you, I often wake up in the morning wishing I had an eight-incher instead of a six.
-- John - Central Ohio - "too much is never enough"
View smitdog's profile
smitdog
312 posts in 1981 days
#10 posted 06-10-2014 02:09 PM
Bwahahah! John, I just about spit out my coffee! I find morning the best time to judge if the size of your jointer is adequate…
-- Jarrett - Mount Vernon, Ohio
johnhutchinson
#11 posted 06-10-2014 02:59 PM
Sorry about that, but how can I read …
“Still, an 8 incher would be nice. Hey, a guy can dream, can’t he?
Oh well. Onward and upward.”
... and keep a straight face.
No points for that one. Too easy. :)
MT_Stringer
#12 posted 06-10-2014 03:16 PM
Yep, that was a good one.
View Mike Throckmorton's profile
Mike Throckmorton
124 posts in 1540 days
#13 posted 06-10-2014 03:48 PM
This is where some degenerate chimes in with the whole is it important whether it’s helical or straight issue.
-- You are never complete, you just draw a line where done is and stop at that line.
MT_Stringer
#14 posted 06-10-2014 04:13 PM
“FWIW, I ran smack into the jointer width problem myself last night. Much of my stock is 8+ ” wide. So even an 8” jointer would be too narrow… Solved it straight away with a planer jointing sled. It’s a bit ackward starting stock through the planer, but it works well enough I almost, but not quite, wonder why I bother with a jointer…”
@DB – do you give free home demonstrations? I could drop by just about anytime you have a few minutes to spare. :-)
I would like to see your sled in action.
Thanks
Mike
