retrofitting delta T2-30
Forum topic by greenfinger posted 06-10-2014 02:36 AM 919 views 0 times favorited 3 replies Add to Favorites Watch
View greenfinger's profile
greenfinger
5 posts in 2940 days
06-10-2014 02:36 AM
I have a Craftsman table saw that had a bad fence, after do some research found information on retrofitting a Delta T2 fence. I attempted this on Saturday, was successful with the front rail with little problems. The back is a little different, I noticed that there is some excessive play up and down on the rail and it doesn’t sit flush on the rail. There is little if any movement side to side. I was wonder if I have done something wrong or could someone possibly give me some direction in which way to go remedy this problem or is this normal. Thanks in advance for the help.
3 replies so far
View knotscott's profile
knotscott
8103 posts in 3461 days
#1 posted 06-10-2014 09:16 AM
Check for burrs or debris preventing the rail from sitting flush, then be sure all the bolts are tightened up. Is it possible that the rear bolts are too long?
View hotbyte's profile
hotbyte
991 posts in 3061 days
#2 posted 06-10-2014 12:06 PM
The rear of fence should have a nylon bushing that just glides on top of the rear rail. There is a small metal clip that goes under the rail to keep the rear of fence from lifting when using a feather board or similar device that could cause an upward force on the fence. The rear of the fence will have some up & down play even when the front is securely locked in place.
greenfinger
#3 posted 06-14-2014 03:31 AM
Thanks for the replies. @ hotbyte I will try to post a picture of the fence on the rear rail, if you let me know if what you see is normal. Appreciate the help.
