Extra long/high Chamfer bit?
Forum topic by jimmy J posted 06-09-2014 03:19 PM 739 views 0 times favorited 3 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2315 days
06-09-2014 03:19 PM
I’m looking to chamfer a table edge with a 15 degree bit, which is a standard angle. My table is 1.75” thick, but, the longest bit I have found is 1” vertical of cutting surface. I’d rather not buy a custom made bit. anyone have a suggestion? I looked at MCLS and Freud but 1” is the longest they carry.
my backup idea was to use the 1”, then turn the piece over and use a 14.5degree dovetail bit. But not sure if that is safe or not – there is no bearing on dovetail bits.
3 replies so far
View jmartel's profile
7751 posts in 2086 days
#1 posted 06-09-2014 03:37 PM
Personally I’d just use a circular saw (set at 15 deg) and clean it up with a hand plane or a sander. At least if I’m understanding it right.
jimmy J
#2 posted 06-09-2014 03:55 PM
Thanks Jmartel. That would work on the short ends of my table, but the long side of the table has a slight curve to it so i need to follow a template with a router.
View Loren's profile
10115 posts in 3584 days
#3 posted 06-09-2014 04:12 PM
Make a canted sub-base for your router and use a long flush trim bit.
