Band Saw Pocket Hole Cutting Jig
Forum topic by Kelly posted 06-08-2014 07:49 PM 2101 views 0 times favorited 2 replies Add to Favorites Watch
View Kelly's profile
Kelly
1875 posts in 2820 days
06-08-2014 07:49 PM
Topic tags/keywords: pocket pocket hole plugs pocket hole jig jig bandsaw band saw pocket plug
POCKET HOLE PLUG CUTTING JIG FOR THE BAND SAW
I’ve seen several well designed pocket hole plug cutting jigs for use on the table saw. However, I opted to perform the operation using the band saw, instead. This is the jig I built for the task.
The grooves are just wide enough to hold a 3/8” dowel. One runs at seventy-five degrees from the front center (from the stop) of the jig to the upper left.
To make the “seventy-five” degree cut, I placed about a one inch spacer between the jig and the fence. This insured the groove would remain flat at the back of the groove in the jig. Then, I set my miter box to fifteen degrees and ran three cuts, which gave me a groove wide enough to hold the 3/8” dowel.
I installed a stop on the front of the jig (distinguished by the darker wood in the photo). It drops down about a quarter inch lower than the jig. It isn’t necessary, but stops you from running well past the cut point, so helps efficiency and improves safety.
At the back of the jig, parallel to the front of the table, is another groove, also cut large enough to hold the 3/8” dowels. It’s used to cut the plugs to length.
The back, parallel groove has a stop (upper left). The stop allows quick positioning for cutting plugs to length. The stop has an elongated hole, which allows minute adjustments for plug length settings.
I carved a finger positioning groove, which drops down into the cut off groove. This is positioned just in front of the cut-off stop and makes holding the cut offs a bit easier. It also helps to position your finger away from the blade.
For extra safety, I installed what I call a doze block. It’s just to the right of the finger positioning groove and just before the seventy-five/fifteen degree groove. It’s just to help keep your finger out of the path of the blade when cutting the plugs to length and should help in event one is distracted during repetitious, monotonous cut off operations.
I mad a three pocket holes on the bottom right to allow tests of the end product. The enlarged holes from the smaller part of the pocket hole drill bit are so the plugs can be popped back out with relative ease.
One could use the fence as a guide, but I opted to use a follower guide, which rides in the miter slot.
To use the jig, I lay a dowel in the groove and position it far enough into the jig to get a full angle on the end of the dowel. Then, run the jig into the blade, until the stop reaches the table.
Once the cut is made, a mark can be made on the jig to indicate where the dowels must stop to get consistent plug lengths for all future cuts.
After the first cut, move the dowel forward and make a second cut, which produces a double pointed dowel. Continue this process to produce however many plugs you desire.
Place each double pointed dowel piece in the back, parallel groove with one of the points against the stop block. Hold it in position by placing your finger in the finger notch, referenced above, and run the piece into the blade to produce two pocket hole plugs.
When pulling back to clear the blade, avoid moving the long dowel piece remaining in the groove. This stops the waste piece from turning in the groove and reduces the times the waste piece will move and stop you from pulling the jig back from the blade (when the waste catches on the blade and the back grooves).
Making a single cut, then moving the cut off to the trim groove produces about thirty plugs and produces waste pieces that can be used for paintable projects where caulking is not a problem.
Making double pointed cuts produces forty-nine plugs.
2 replies so far
View exelectrician's profile
exelectrician
2327 posts in 2303 days
#1 posted 06-09-2014 05:13 AM
Very interesting and well thought out jig. Thanks for posting.
-- Love thy neighbour as thyself
Kelly
#2 posted 06-10-2014 07:27 AM
Ran a couple downs to see how it worked out. I ended up getting one of my carving chisels and notching for a finger to hold the dowel in place just in front of the stop at the back (when cutting plugs to lenght.
I run the dowel in to the blade to get the angle. Then I place the point in the top groove with the point up against the stop. Then I go back to the other groove and cut the next angled piece. This leaves an angled piece just like the keeper, but which won’t quit fill the hole. However, if you’re painting, a little caulk with take care of the tiny gap.
I saved all the trimings and they’ll make fine plugs for holes that can be caulked and painted, which somewhat doubles the end result (I have a place I can use them right now)
Tomorrow, I’m modifying my technique to see if I can cut so I can increase the number of full plugs and do away with the shorter, waste ones. Will relay the details.
