why does polyurethane pull away from growth rings?
Forum topic by strandedpirate posted 06-08-2014 05:55 PM 1269 views 0 times favorited 11 replies Add to Favorites Watch
View strandedpirate's profile
strandedpirate
8 posts in 1322 days
06-08-2014 05:55 PM
Topic tags/keywords: oak finishing polyurethane
I’ve applied several coats of polyurethane to a stained oak seat. When first applied the poly is smooth and even, then as it dries it pulls away from the growth rings.
Have I applied it incorrectly or is this normal? Any way to get a perfectly smooth finish?
I stained the seat then put two layers of sanding sealer on it followed by four layers of the poly but it still pulls away from the growth rings no matter how many layers of poly I apply.
11 replies so far
View johnstoneb's profile
johnstoneb
2691 posts in 2044 days
#1 posted 06-08-2014 05:59 PM
It’s not pulling away from the growth rings it is going into to fill the voids. You will need many more coats and sand between each coat until everything is filled. Open grain woods require a filler before the finish. if you don’t want to put on many coats of finish to act as a filler.
-- Bruce, Boise, ID
View bondogaposis's profile
bondogaposis
4525 posts in 2222 days
#2 posted 06-08-2014 07:10 PM
It is not pulling away from the pores it is being sucked inside them. They are like straws. You need to fill them before they will stop doing that. One way to do that is to take some 0000 steel wool and load it with tung oil and polish the wood with it to form a slurry, then wipe it off and let dry. Then apply your finish over that. This is a micro photograph to help you understand what you are dealing with at the cellular level.
-- Bondo Gaposis
View gfadvm's profile
gfadvm
14940 posts in 2561 days
#3 posted 06-09-2014 12:42 AM
Great explanation and pic Bondo!
strandedpirate
#4 posted 06-09-2014 04:07 PM
Thanks, do I need to strip the existing poly off or can I apply tung oil over it?
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2226 days
#5 posted 06-09-2014 04:48 PM
I do not think you can add the tung oil now, unfortunately, it would have bade effects.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View b2rtch's profile
b2rtch
4847 posts in 2919 days
#6 posted 06-09-2014 04:55 PM
You could buy and apply a filler but normally you apply the filler before finishing.
Back home we had a product named ” fond dur” which was filler and finisher as the same time. In the USA , I do not know of one.
http://www.blanchon.com/produits-bois/distribution-pro-du-bois/produit-pro-interieur/couche-primaires-pro/fond-dur-preplast.html
-- Bert
bondogaposis
#7 posted 06-09-2014 04:57 PM
It is probably too late for the tung oil treatment at this point. If you really want a level surface you will have to strip and start over I’m afraid. Your seat doesn’t look that bad to me and if it were mine I would probably give it a few more coats and then top it with some paste wax and call it good. It depends entirely on the look you want. Another way to go is to enhance the look of the pores by using a colored wax to bring them out, black bison wax comes to mind. It will darken all of the pores and really make them stand out, kind of an antique effect.
-- Bondo Gaposis
TCCcabinetmaker
#8 posted 06-09-2014 05:08 PM
Rather than strip it, just sand the finish coat heavily and reapply, if the pores are still very noticeable, then repeat, each time sanding a little heavier with 220 grit sand paper. Make sure to wipe away all dust as it will not melt back into the finish with polyeurathane.
You are only supposed to let most finishes get so thick, so a lot of coats without sanding can cause the poly to crack and peel, well most finishes will do that if you get them too thick, except maybe laytex.
View ChefHDAN's profile
ChefHDAN
1007 posts in 2721 days
#9 posted 06-09-2014 06:57 PM
I learned this same lesson the hard way refinishing a QS oak table, I spent weeks trying to get a flat surface, stripper, sanding, cursing, screaming, all to no avail, the finish never seemed to “flatten out”, rottenstone was probably the only thing I didn’t try, and finally resigned myself to liking the table the way it was. For my next project with oak I used Famowood filler and got great results after the first coat.
strandedpirate
#10 posted 06-09-2014 11:53 PM
I went ahead and heavily sanded to level the surface out. Looks much smoother now with a few stubborn areas refusing to fill up with poly. It’s definitely smoother when viewed at an angle with the light casting on it, but more than smooth enough to the touch so I’ stopping here and moving to the next project.
View lateralus819's profile
lateralus819
2241 posts in 1761 days
#11 posted 06-10-2014 12:01 AM
I think that looked awesome!
