Dremel stand or drill press for scroll work?
« back to Scrollsawing forum
Forum topic by cdaniels posted 06-07-2014 10:51 PM 2995 views 0 times favorited 8 replies Add to Favorites Watch
View cdaniels's profile
cdaniels
1320 posts in 1527 days
06-07-2014 10:51 PM
So after working with my new scroll saw it’s more apparent that I need some kind of drill press. Question is do I just get the dremel press since I have the biggest dremel available( love the tool) or do I dive in and get a tabletop drill press? Keep in mind I’m in a wheelchair so a big press is a no go. Don’t know what to get but want to keep it at 200$ or less. Percolate the advice.
Iron Sides
-- Jesus was a carpenter... I'm just saying
8 replies so far
View Redoak49's profile
Redoak49
3283 posts in 2014 days
#1 posted 06-07-2014 11:54 PM
I think that a bench top drill press might be useful and there are quite a few for under $150. You may need to get an adapter to handle the very small drill bits. That is what I do.
The people who do a lot of fretwork where you need to make a lot of very small holes sometimes use a specialty small drill press made specifically for doing that. You might read some more on the Scrollsaw Woodworking and Crafts website/.forum
View Don1's profile
Don1
37 posts in 3775 days
#2 posted 06-08-2014 03:59 AM
I use a drill press but Seyco has this one for $129 which may work for you.
http://www.seyco.com/category/sdrill.html
Don R
-- www.oldcrowscrollwerks.weebly.com
View Paul's profile
Paul
721 posts in 1591 days
#3 posted 06-08-2014 04:22 AM
Cdaniels,
Being in a wheel chair, are you able to stand for brief periods? I ask this because a lot of drill presses require changing belt locations on pulleys on top of the drill press to change speeds. If you are solely in your chair alone that might pose problems if you have the need to change the speed on the drill press. Do you have a helpful hand near by?
I have 3 dremel’s even the most robust of them will not match a true bench top drill press. If you have the means of changing the belt ever so often for speed changes I would recommend a bench top drill press. If this is not an option for you I would go with the dremel press option.
Paul
View Jim Finn's profile
Jim Finn
2658 posts in 2948 days
#4 posted 06-08-2014 01:26 PM
I have a bench top drill press and a Dremel tool drill press. I do a LOT of scroll saw work and I drill all my starter holes at an angle (Doing inlay work) with the Dremel set up. I have a Black and Decker rotary tool mounted in my Dremel drill press accessory, using a 1/16” drill bit, and it works fine for me. I tried using my much larger drill press for this but found that it broke the small drill bits much to easy to suit me.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View TheDane's profile
TheDane
5441 posts in 3689 days
#5 posted 06-08-2014 01:35 PM
cdaniels—I would go with the Dremel with a plunge router base setup instead of a drill press. You already have a Dremel and the plunge base can be had for under $50 … here is the one I have:
http://www.toolbarn.com/dremel-335.html?gclid=CjkKEQjwk9CcBRDEopHmnZa5td8BEiQAr2BckNUesc_9XT0xZKgw57V11skMA1m1T4psxAfuzyckeGHw_wcB
While there may be other uses for a drill press, the Dremel is much easier to handle and can take much smaller bits than a standard drill press chuck.
I have a drill press as well as a Dremel with a plunge base and use the Dremel for all of the entrance holes in my scroll work.
View kepy's profile
kepy
293 posts in 2299 days
#6 posted 06-08-2014 02:33 PM
The Dremel plunge router base is much more useful than the drill press attachment as it does not limit the size of the material.
-- Kepy
View JesseTutt's profile
JesseTutt
854 posts in 2136 days
#7 posted 06-08-2014 02:34 PM
+1 for what TheDane said. I have one from Milescraft and it works ok. You could add angled shims with double sided tape if you need angled cuts.
View jerrells's profile
jerrells
918 posts in 2910 days
#8 posted 06-09-2014 03:00 AM
I use the Dremel drill press a lot but I also have a bench top for larger work. I think you could get by with the Dremel for a long time.
-- Just learning the craft my Lord and Savior Jesus Christ practiced.
