A favored tool
« back to Hand Tools forum
Forum topic by dubois posted 06-07-2014 10:46 PM 1136 views 0 times favorited 6 replies Add to Favorites Watch
View dubois's profile
dubois
41 posts in 1852 days
06-07-2014 10:46 PM
Hello,
This is my axe, a carpentry axe sure and true but no longer are they made which is sad.
E.DB.
View DocBailey's profile
DocBailey
584 posts in 2381 days
#1 posted 06-08-2014 04:50 AM
Not true – Gransfors and Wetterling (just for two examples) still make these.
dubois
#2 posted 06-08-2014 09:09 AM
Ok they make an axe that looks like this one and in fact are inspired by it but are a far cry from the example you see. For one thing, a close look at the bevel will show that the cutting edge of this axe is an insert of high carbon content steel surrounded by a milder iron. The ones you mention, fine axes indeed, still, pale imitations.
E.DB
DocBailey
#3 posted 06-08-2014 01:33 PM
Who is the manufacturer of yours?
View Buckethead's profile
Buckethead
3194 posts in 1890 days
#4 posted 06-08-2014 01:45 PM
This academic stuff is all fine and good, but let’s see this beauty in action!
-- Support woodworking hand models. Buy me a sawstop.
dubois
#5 posted 06-08-2014 03:16 PM
Here is literally some action, I don’t know if it’s what you mean, a sort of example of some work underway where I use this carpentry axe.
https://vimeo.com/95651594
If we can speak of a “manufacturer” I don’t know, the axe was made by Johan Skog in his small blacksmith shop in Hjärtum mid-way on the old road between Göteborg and Trollhättan sometime prior to 1963.
E.DB.
bandit571
20207 posts in 2705 days
#6 posted 06-08-2014 04:03 PM
There is a Hand Tool forum coming out of China
The “spokesperson” doing the work, uses a ”#2” carpenter’s hatchet. Cuts bevel on the edges of items being made. Uses either the side or the non-edge end to drive his Mortise chisel. He will even make adjustment to the settings on his Hand Planes…
Seems to be a lot of these shows, all under the GE Hong name…
