| Forum topic by woodbutcher | posted 309 days ago | 468 views | 0 times favorited | 4 replies | ![]() |
309 days ago |
O.K. before I ruin an expensive piece of UHMW fence face, I gotta know! Do any of you Lumberjocks run this material through your planners to get a fence face flat? I’ve got about .007” difference across the face. I’m dead nuts on either end of the fence in relation to the miter slot on the table saw, but there is approximately .006” to .007” dip in the middle of the fence. I assume its probably just wear as measures this way about 4” in front and behind the blade before being true again at both ends of the fence and miter slot. What is your suggestion on the best method to correct this? I want everything parallel if I’m spending this time to dial the saw in. Next question is. Are you commonly seeing as much as .011” run out on your saw blades? I’ve got the miter slot within less than .001” square from front to back of blade. I tickled pink with this measurement! Just not extremely happy with the blade that’s on there having .011” run out even though it’s cutting great. Any help would be greatly appreciated-TY-in advance. -- woodbutcher north carolina |
