Drawer Bottom
Forum topic by boatz posted 06-06-2014 02:56 PM 786 views 0 times favorited 2 replies Add to Favorites Watch
View boatz's profile
boatz
92 posts in 1560 days
06-06-2014 02:56 PM
I am building a multipurpose cabinet for my shop. It’s primary use will be for my miter saw. The saw is mounted on a removable base on top of the cabinet. I want to be able to remove the miter saw and store it in the cabinet below. I am installing a tray type drawer with full extension slides so I don’t have to reach in and lift it out. The saw and base are close to 50 lbs.
What should I use for the drawer bottoms and what type on joint to attach to the low sides to which will be mounted the drawer slides.
Thanks in advance for the advice.
-- You can't always get what you want. But if you try sometimes you just might find, you'll get what you need
2 replies so far
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#1 posted 06-06-2014 03:02 PM
1/2” plywood, set in dadoes.
-- Bondo Gaposis
boatz
#2 posted 06-07-2014 01:58 AM
Thanks for the tip. I wasn’t sure whether to use a dado or rabbet
