GO555 running rough.
Forum topic by Jim Finn posted 06-05-2014 03:19 PM 1152 views 0 times favorited 2 replies Add to Favorites Watch
View Jim Finn's profile
Jim Finn
2656 posts in 2919 days
06-05-2014 03:19 PM
Topic tags/keywords: bandsaw
I have had my GO555 for over five years and it started thumping as it ran. It would come and go. Last week I tore into it and found a lot of play in the lower wheel. I took it apart and found the two bearings to be just fine but the wheel shaft appeared to be worn a bit under one of the bearings. I had to use a gear puller with a lot of force to get the shaft out of the wheel. Grizzly sent me a new shaft in short order at a cost of $9.50 + $8.50 shipping. I put it together today and it solved the problem. Runs as smooth as it did when it was new. The new wheel shaft just took a little tapping and some WD-40 and it when right on. Good to have my saw back up and running. I use this saw mostly for re-sawing.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
2 replies so far
View NikkiLaRue's profile
NikkiLaRue
296 posts in 1479 days
#1 posted 06-05-2014 03:22 PM
Glad you were able get it back up and running!
View Druid's profile
Druid
1754 posts in 2792 days
#2 posted 06-06-2014 05:34 AM
So, do you now refer to your saw as “Thumper”?
Glad to hear that the problem has been solved to your satisfaction.
-- John, British Columbia, Canada
