Have a new to me dust collector...Now what?
Forum topic by natenaaron posted 06-04-2014 06:46 PM 869 views 0 times favorited 4 replies Add to Favorites Watch
View natenaaron's profile
natenaaron
442 posts in 1699 days
06-04-2014 06:46 PM
A local business has sold out because the husband died. It was obvious I could have gotten the dust collector for a lot less than what I did but I just did not feel right doing that to the widow. Word has it she will have a struggle. So now I own a 1 hp delta dust collector. I know I should put a 2 hp motor on it but was wondering if it was necessary? The next question is should I build a thein (sp) separator, or get a dust deputy?
I don’t do a lot of wood work, just hobby stuff, and I don’t mind rolling it around right now between the few tools I have.
4868 posts in 2395 days
#1 posted 06-04-2014 07:08 PM
Putting a 2 HP motor on it isn’t going to do much unless the current motor is overloading (drawing too many amps). Here’s why: the current motor is spinning the impeller at 3600 RPM (or whatever) and that’s the most air the thing will move. Put a larger motor on it and that same impeller will spin at (ta-da) 3600 RPM (or whatever), assuming it’s a 3600 RPM motor. I’d suggest you build a Then and try it out, see if you’re happy with the performance and go from there.
View toolie's profile
toolie
2105 posts in 2530 days
#2 posted 06-05-2014 01:35 AM
a pre-separator with a thein baffle will probably rob more suction than the unit (probably 650cfm) can tolerate. if it’s an ap400, i’d sell it for at least something in the league of a 50-850.
natenaaron
#3 posted 06-05-2014 08:29 PM
Well that is a bummer. Guess I’ll wait for a 20% off coupon and get the HF one.
View johnstoneb's profile
johnstoneb
2779 posts in 2074 days
#4 posted 06-05-2014 08:40 PM
If you are just moving from 1 machine to another that will be plenty of dust collector. To me the main benefit of the separator is ease of emplying the collector and length between services on the bags. I would use it as is and then you can determine if you want to build the separator or upgrade to more capacity. If you have a planer you will probably want a separator. Saws,sander etc. you will be fine with just the collector.
-- Bruce, Boise, ID
