Outfeed table workbench
Forum topic by woodworkingdrew posted 06-04-2014 02:36 PM 3162 views 2 times favorited 20 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1752 days
06-04-2014 02:36 PM
I was wondering if anyone has made a workbench the same height as a table saw and used it for both a bench and an outfeed table. I dont have room to build a stand alone outfeed table and would like to option to attach the outfeed table to the TS then disconnect it for storage purposes. Thanks!
-- Andrew, California
20 replies so far
View ryguy's profile
ryguy
37 posts in 3095 days
#1 posted 06-04-2014 02:46 PM
I will tell you what I use- an old drawing table that artists used to use before everything went digital. I can move it around the shop and use it for a multitude of things and it can raise and lower in addition to tilting. It really works great for me.
-- Ryan, Cincinnati, OH
View TheDane's profile
TheDane
5523 posts in 3806 days
#2 posted 06-04-2014 02:52 PM
I built a rolling cabinet that I can double as an outfeed table …
Click for details
It works pretty well … the one thing it lacks (for obvious reasons) is a set of grooves that match the miter tracks on the saw.
View NiteWalker's profile
NiteWalker
2738 posts in 2720 days
#3 posted 06-04-2014 03:38 PM
My outfeed table is attached to my saw, but my workbench is just below it in height so it works as an extended outfeed surface.
When I get my sawstop, I’m building a workbench/outfeed table for it. The only disadvantage to a workbench that doubles as an outfeed table is that it needs to be cleared off when you need to use the table saw.
View kdc68's profile
kdc68
2689 posts in 2420 days
#4 posted 06-04-2014 03:56 PM
Here’s an outfeed table/workbench with storage that is also portable. I chose to have the height of this unit about 7/16” below the height of the table saw top thus eliminating the need for miter slots. No issues and works well for me at this height.
Click for details
-- Measure "at least" twice and cut once
View InstantSiv's profile
InstantSiv
262 posts in 1738 days
#5 posted 06-04-2014 04:53 PM
I have a similar setup as kdc68. My workbench is on casters and sits 1-1/4” lower than my table saw. If I need an out-feed table I wheel it behind the saw and put a 3/4” sheet on the workbench along with a 1/2” sheet on top of that.
woodworkingdrew
#6 posted 06-05-2014 01:28 AM
KDC- that’s a spiffy looking setup you have there. I would have no use for the drawers but I like the top design. Is that malamine? Also I really like those faster wheels, mind sharing where you bought those? Thanks
kdc68
#7 posted 06-05-2014 01:36 AM
Andrew...the top is made up of 3 layers of 3/4” MDF and I have HPL (high pressure laminate) on both the top side and the underside. The wheels are Workbench Castors from Peachtree Woodworking. If you click on the attachment in post #4, it will take you to my project. I have details on everything there. But if you have more questions just let me know, I’d be happy to help
View redSLED's profile
redSLED
790 posts in 2036 days
#8 posted 06-05-2014 04:02 AM
Yes, I have – workbench works fine as outfeed table. Using portable table saw on locking casters stand. I went with 35” high.
Considering a small workshop may have a router table and/or assembly table/cart and/or miter saw stand and/or planer stand and/or workbench and/or drill press/stand and/or other rolling cart, it seems totally inefficient IMO that one would add an outfeed table to the space.
Now, adding a good 2-channel 100+W stereo amp with aux cable and medium to big speakers (for adequate ‘soundstage’ depth) would also be efficient – for your audio enjoyment.
View TheFridge's profile
TheFridge
10280 posts in 1629 days
#9 posted 06-05-2014 04:42 AM
Sounds awesome. The dust would never settle on my shop if I had that setup.
View bonesbr549's profile
bonesbr549
1576 posts in 3210 days
#10 posted 06-06-2014 02:37 AM
Sure have. I’m a big fan of multi use to make the most of my space. My table is a a top with vices and the legs were made out of 2×6” and I used a forstner bit to put holes in the bottom. I inserted adjustable leg bolts in so I could adjust the height. I match that to the height of my table saw so it is just below the height of the TS top. Works great.
View MT_Stringer's profile
MT_Stringer
3173 posts in 3374 days
#11 posted 06-06-2014 02:58 AM
Everything in my one car garage is on casters or mobile bases except for the outfeed table/work bench.
Here are links to my stuff. Maybe you will find some inspiration.
Good luck.
Mike
New work bench
Mobile workstation
Adjustable height work table/router table
View NormG's profile
NormG
6252 posts in 3147 days
#12 posted 06-06-2014 03:13 AM
That is pretty darn handy alright
-- Norman - I never never make a mistake, I just change the design.
Craftsman on the lake
2810 posts in 3581 days
#13 posted 06-06-2014 03:19 AM
Here’s mine and the video where I show more of it.
NiteWalker
#14 posted 06-06-2014 12:01 PM
Mike, the mobile workstation is pretty cool. I like the top configuration.
View KDO's profile
KDO
154 posts in 2913 days
#15 posted 01-27-2015 12:08 AM
I too am in a double car garage for my shop and have limited space. I have a 4’x8’ work table that sits directly behind my TS and is used as an outfeed table when needed. It is about 3/4” below the level of my TS so a sled or miter will move straight onto the table without the sled’s runners getting hung up.
I love the setup. In a small space, it makes great use of the available space.
It sits with the 4’ side next to the TS, so the long side gives me a good workspace.
Mine is free standing and is not attached to the TS so if I need to move my TS sideways or backwards, I just loosen a couple of locking casters and move the saw.
(Edit). Hmmm…I just saw the date of your post. I guess I’m a little late. Hope you got things figured out.
-- Christian, Husband, Grandpa, Salesman, amateur Woodworker.
