Need Help Wiring a 120/240 single phase motor
Forum topic by TheWoodenOyster posted 06-04-2014 01:10 AM 2709 views 0 times favorited 7 replies Add to Favorites Watch
TheWoodenOyster
1313 posts in 1897 days
06-04-2014 01:10 AM
Topic tags/keywords: bandsaw
Hey Everyone,
I picked up a 1960’s powermatic 81 bandsaw a few days ago. We took the motor out to load it into the truck. The guy I bought it from swore that all I needed to do was look at the wiring diagram and I would know exactly how to rewire it when I got home. Well, I have never wired a motor before, and I know it is relatively simple, but I can’t figure out how to rewire this thing. I have attached photos of the the motor wiring diagram and the 3 wires that are hanging out of the saw.
He had the following wires coming out of the motor twisted together:
1 and 8 together
7 and 6 together
2,3, and 5 together
So, coming out of the saw I have a black, white, and green wire. I know I am supposed to wirenut each of these three colors to a corresponding group of wires coming out of the motor.
So, which bunch of motor wires goes with which wire coming out of the saw?
And what do “tape” and “line” mean on the diagram?
Last, did this guy even have it wired correctly?
Thanks so much for the help guys. I tried to find a good answer online, but it was a waste of time. I am sure one of you will be much more informative. Hopefully this will be the first and last time I will have to learn how to wire these simple motors.
-- The Wood Is Your Oyster
7 replies so far
10242 posts in 3610 days
#1 posted 06-04-2014 01:30 AM
“Tape” means twist the wires together and put a wire nut
over the wire ends, then put electrical tape over it.
Green is always ground.
The motor is wired for counterclockwise rotation at 220v,
see the statement under the diagram?
He’s got 6 and 7 wired together wrong. It may be
harmless, but I would tape off 7.
TheWoodenOyster
#2 posted 06-04-2014 01:40 AM
Thanks,
So 6 should be attached to black (or white)
1 and 8 should be attached to white (or black)
2,3, and 5 should be attached to green
and 7 should be capped
Correct? I am assuming that you can attach the “line” bunches to either black or white
#3 posted 06-04-2014 02:20 AM
Yes, “line” is black or white. At 110v line is black and white
is neutral but they are reversible as neutral functions as a ground
wire and only one “hot” wire is used at 110v.
Green should not be attached to any of the other wires. It
should be attached to a ground nut behind the panel
which is usually green colored but can be any nut attached
to the body of the motor. If there is a junction box
on the motor, the ground nut can be one of the screws
attaching the box to the motor.
TheWoodenOyster
#4 posted 06-04-2014 02:56 AM
Cool. I think I got it. Thank you
View jonah's profile
jonah
1655 posts in 3261 days
#5 posted 06-04-2014 11:56 AM
Unless my eyes deceive me, it should be this for 240V:
1+5 wire nutted together with one of the hot wires
6 wire nutted together with the other hot wire
2+3+8 wire nutted together attached to nothing
7 wire nutted by itself
For some reason there is no wire #4. As Loren notes, the ground should be attached to a ground terminal screw somewhere inside the wiring box. If you can’t find one, attach it to any metal screw inside the metal box.
You said 1+8, but the picture says 1+5 for 240V.
jonah
#6 posted 06-04-2014 11:58 AM
Is there some reason the previous owner had it set up to run counter-clockwise? That’s what you get when you exchange wires 5 and 8.
TheWoodenOyster
#7 posted 06-04-2014 02:10 PM
Yes, the saw is set up for a counter clockwise motor.
