Millers Falls hand plane
« back to Hand Tools forum
Forum topic by TiggerWood posted 06-04-2014 12:49 AM 1605 views 0 times favorited 9 replies Add to Favorites Watch
View TiggerWood's profile
TiggerWood
271 posts in 1480 days
06-04-2014 12:49 AM
I was rehabbing a Millers Falls hand plane and decided to test what looked like a glued up broken tote. It snapped with pinky pressure. The wood is mocha chocolate color. What wood did they use on these old hand planes? I’m sorry, I didn’t think to take any pictures before gluing it up. It’s a very soft, brittle, and light wood.
9 replies so far
View ColonelTravis's profile
ColonelTravis
1725 posts in 1767 days
#1 posted 06-04-2014 01:03 AM
If you’ve got their top line planes, then the older ones were rosewood or cocobolo. During and after WWII they used a few different kinds. You can check your type here.
If yours is from their lower-tier line, no clue.
View Don W's profile
Don W
18561 posts in 2441 days
#2 posted 06-04-2014 01:06 AM
drill down here http://oldtoolheaven.com/bench/bench.htm and when you find yours you will fnd the wood they used.
here is how I fix the breaks. Clean it with mineral spirits. Then take the smallest bit you have and drill a series of small shallow holes. This gives the epoxy something better to grab. You can darken epoxy with charcoal from a pencil if you don’t have anything else, the epoxy it back together.
TiggerWood
#3 posted 06-04-2014 01:16 AM
It appears to be a type 2. I thought cocobolo was a hard wood. The texture of this is a lot like cedar, but not.
View shampeon's profile
shampeon
1775 posts in 2057 days
#4 posted 06-04-2014 01:23 AM
Yeah, cocobolo would not resemble cedar. Keep in mind that the model matters here. Only the premium bench planes had cocobolo or goncalo totes/knobs. And also that type 2 planes might have type 3 handles if they were produced just after the war.
TiggerWood
#5 posted 06-04-2014 01:37 AM
The dark swirls are the wood grain.
Don W
#6 posted 06-04-2014 09:56 AM
I agree with Ion. I’ve never had a MF plane with a tote anything like cedar. Actually most of them come out looking really good once you get the original finish off.
shampeon
#7 posted 06-04-2014 03:48 PM
That tote doesn’t look like a typical type 2 or 3 toe. The type 4 totes made of goncalo are a somewhat similar color after removing the red-tinted varnish, but are a different shape (more upright), and goncalo is dense and hard like cocobolo.
Is it just the picture, or is the knob significantly darker than the tote? Could the tote have been replaced at some point?
View Rick's profile
Rick
8576 posts in 2906 days
#8 posted 06-05-2014 06:28 AM
OH! Good! You’re Using the Site Pic/img Downloader now I see.
-- A Chip On The Shoulder Usually Indicates Wood Higher Up. (Rick, Ontario, Canada)
TiggerWood
#9 posted 06-11-2014 02:52 PM
Shampeon No, the tote and knob are precisely the same.
Rick I always could post pics in comments but I still can’t do anything with projects.
