How dry must Maple be?
Forum topic by TedHains posted 06-03-2014 06:02 PM 1242 views 0 times favorited 15 replies Add to Favorites Watch
View TedHains's profile
TedHains
21 posts in 3034 days
06-03-2014 06:02 PM
Topic tags/keywords: maple
I had a Maple log sawn to 5/4 last August, stacker with dividers stored under a tarp in North MN. what moister should it be down to so I can make a Table?
-- God determines the number of days, but you determine how they are spent. Ps 118:24
15 replies so far
View pintodeluxe's profile
pintodeluxe
5816 posts in 3050 days
#1 posted 06-03-2014 06:29 PM
Once it is down to 14-15% moisture content, you can take it inside to dry it out. Either set up a kiln with a home dehumidifier, or bring it into a climate controlled shop. Once it is 6-8% you are ready to build.
Shawn Masterson
1325 posts in 2186 days
#2 posted 06-03-2014 09:40 PM
IMHO 6-8% seem low. The wood will equalize to the ambient moisture where it is. I have never used a moisture meter. I generally leave my wood stickered and stacked with a roof cover (open on the sides) for 1 year an inch.
View kdc68's profile
kdc68
2692 posts in 2514 days
#3 posted 06-03-2014 10:34 PM
Acceptable moisture content (MC) is a variable depending on the in-use location, say 6 to 14%...??....
Ideally the moisture content should be within 2 percentage points of the equilibrium moisture content (EMC) of the in-use location…..
I’m sure I will be corrected if I am wrong… I will follow this post to see…. ;-)
-- Measure "at least" twice and cut once
View Hammerthumb's profile
Hammerthumb
2908 posts in 2212 days
#4 posted 06-03-2014 10:39 PM
Agree with kdc68. Here in Las Vegas mc will get below 6% in my shop. If I was in Florida it might be as high as 14-16%. When the moisture content reaches equilibrium (stops changing) is when it is ready.
-- Paul, Duvall, WA
Hammerthumb
#5 posted 06-03-2014 10:41 PM
By the way, typical kiln drying will be between 6 to 9%.
-- Paul, Duvall, WA
View WDHLT15's profile
WDHLT15
1797 posts in 2713 days
#6 posted 06-04-2014 01:51 AM
If the table is to be used in a house, 8% is a good target. If you air dry it to 15%, then bring it inside and sticker it inside you house in an out-of-the-way place, it will reach equilibrium in 3 or 4 weeks. The equilibrium M% will be lower in winter due to heating your house. So, design a little shrinkage into your project.
TedHains
#7 posted 06-04-2014 01:55 AM
Thanks Danney
TedHains
#8 posted 06-04-2014 02:02 AM
Thank you one and All, This has been a BIG help.
WDHLT15
#9 posted 06-04-2014 02:08 AM
Maple will air dry to 15% here in Georgia in 3 – 4 months. A little faster if you keep a couple of fans on the stack. In more Northern climates, it will dry slower. You have to have good air flow or the lumber will gray stain. It is an enzymatic oxidation reaction in the wood that occurs in high humidity and warm temperatures. The fans really help a lot to prevent it, but I always seem to get some gray stain when air drying maple.
Shawn Masterson
#10 posted 06-04-2014 02:18 AM
I find these numbers very interesting. I had some start of the season AC troubles (fixed 4 days ago) and have my jobsite thermometer in my living room and the humidity on it right now says 42% @72*. I live in northern Indiana. The high low variations for the last 24 hours is 41%-43%(it stores for 24 hours). Am I comparing something wrong here?
WDHLT15
#11 posted 06-04-2014 02:24 AM
At 42% relative humidity and 72 degrees, the EMC (equilibrium moisture content) is 8%.
The numbers sound right.
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#12 posted 06-04-2014 02:46 AM
Dry it a year per inch then acclimate it if possible. Similar to when wood floors are going to be put in a home you want to put it in your house to let the moisture content in the wood and the house equalize.
I put crown molding in my house when I remodeled. It went straight from an outdoor but covered rack at a lumber yard in south louisiana, to cut up and installed in my house. I wondered for years why my crown shrunk weeks after I put it in. It cracked the caulk and caused gaps. It sucked to have to recaulk and repaint.
WDHLT15
#13 posted 06-04-2014 11:44 AM
I would air dry it till it is air dried. The time will vary depending on your location and climate. In the deep South, we get good drying even in winter. The wood never freezes. In the North, there are less good air drying days, and in the winter in many places with lots of snow, there is not much air drying that takes place in winter.
If I air dried wood for a year per inch, I would waste a lot of time. That is why a good moisture meter is important if you dry much wood at all.
TedHains
#14 posted 06-04-2014 01:54 PM
Thank you so much everyone for all the help. I am good now, I found a Kiln to do the drying for me. Happy, Happy.
View Nomad62's profile
Nomad62
726 posts in 3195 days
#15 posted 06-05-2014 03:52 PM
Shawn, air humidity is different than wood humidity. These numbers are stating the percentage of moisture each has in comparison to what each can potentially hold; wood can hold more water volume that air per cubic inch, so it’s moisture content when ready for valid woodworking will read much lower that the air it sets in.
