WARNING
Forum topic by MrRon posted 06-03-2014 05:20 PM 1548 views 0 times favorited 17 replies Add to Favorites Watch
View MrRon's profile
MrRon
5150 posts in 3421 days
06-03-2014 05:20 PM
I had a can of spray paint sitting on the bed of my wood lathe. When I went into my shop a few days later, I found the can had leaked it’s contents under pressure all over the lathe and floor. I asked why this happened on another forum, and I was told UV radiation from fluorescent lighting could cause the cans to leak. I don’t understand that explanation and don’t have any other reasons at hand. All I know; is I now keep rattle cans well away from any place I don’t want accidentally painted.
17 replies so far
View Woodknack's profile
Woodknack
12402 posts in 2558 days
#1 posted 06-03-2014 06:20 PM
Someone is pulling your leg, bulbs don’t put out enough UV to deteriorate metal. The shop probably got very hot or the can was just defective.
View Clint Searl's profile
Clint Searl
1533 posts in 2539 days
#2 posted 06-03-2014 06:39 PM
Twilight Zone
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3763 days
#3 posted 06-03-2014 06:48 PM
Sorry to hear of your mishap and I bet the cleanup was not pleasent.I am afraid however as for an explanation I am with Clint. I wish you well brother for the future. Alistair
View b2rtch's profile
b2rtch
4863 posts in 3226 days
#4 posted 06-03-2014 06:49 PM
That remind me of the time when my wife left a can of coke in my car which was parked in full sun.
What a mess to clean!
-- Bert
View bondogaposis's profile
bondogaposis
5056 posts in 2529 days
#5 posted 06-03-2014 06:54 PM
That reminds of a time I was on a tree marking crew and one of the guys unknowingly dropped an aerosol can and then stepped on it w/ caulk boots. Thought he stepped on a rattlesnake, you should have seen him jump.
-- Bondo Gaposis
View jonah's profile
jonah
1880 posts in 3476 days
#6 posted 06-03-2014 08:50 PM
No way in hell was the lighting responsible. The can was defective. It happens.
View OldWrangler's profile
OldWrangler
731 posts in 1772 days
#7 posted 06-03-2014 09:08 PM
So most importantly, what color is your lathe now?
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
View Surfside's profile
Surfside
3389 posts in 2351 days
#8 posted 06-03-2014 09:17 PM
I don’t think its the lightning ; it’s impossible. You probably just overlooked that the can is defective.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
MrRon
#9 posted 06-03-2014 09:31 PM
The can didn’t open or split. the leak was around the nozzle area. I lied. It wasn’t a paint can, but a can of Dykem Blue marking fluid which uses the same type of aerosol can. The lathe is now a dark blue. I can probably remove it with Dykem ink remover. http://www.grainger.com/product/DYKEM-Blue-Layout-Fluid-2C928
View wheelerspop's profile
wheelerspop
9 posts in 1698 days
#10 posted 06-03-2014 09:35 PM
Same reason you find the spray paint cans with paint and no propellant.
View Picklehead's profile
Picklehead
1048 posts in 2107 days
#11 posted 06-04-2014 01:12 AM
Did you read, understand, and follow all the warnings on the label? {:o)
-- Quote from ebay tool listing: " Has nicks and dings wear and tear dust and dirt rust and pitting but in good working condition"
MrRon
#12 posted 06-04-2014 07:13 PM
The propellant didn’t leak out, it forced the Dykem blue out of the can as it sat there upright.
View Pezking7p's profile
Pezking7p
3217 posts in 1829 days
#13 posted 06-04-2014 07:30 PM
Is it possible that any pressure was on the nozzle? Perhaps the can was resting on it’s side and a slight pressure allowed some dye to bleed out? Otherwise just a bad can.
Seriously, there is nothing that your fluorescents can do to that can.
-- -Dan
View bigblockyeti's profile
bigblockyeti
5262 posts in 1898 days
#14 posted 06-04-2014 08:23 PM
I’ve had cans of lacquer weep a little from the bottom before, making a small crystal clear ball of hardened lacquer, but not one that’s sprayed everywhere. If your lights put out enough UV radiation to deteriorate a steel can, they would have melted you a long time ago.
wheelerspop
#15 posted 06-04-2014 08:39 PM
“The propellant didn’t leak out, it forced the Dykem blue out of the can as it sat there upright.”
Gremlins then.
