Painting mdf
Forum topic by buck_cpa posted 06-03-2014 01:11 AM 1051 views 0 times favorited 8 replies Add to Favorites Watch
View buck_cpa's profile
buck_cpa
150 posts in 1851 days
06-03-2014 01:11 AM
Topic tags/keywords: mdf
Has anyone ever painted mdf sheets prior to cutting and assembling? I am charged with doing builtins in our closet. From experience, painting after assembly is a pain. But I wasn’t sure about sliding painted sheets across my tablesaw and other tools.
8 replies so far
View JAAune's profile
JAAune
1786 posts in 2281 days
#1 posted 06-03-2014 04:15 AM
Cut everything to fit and get it ready for assemble then do the painting. You don’t want to be moving them around more than necessary once the finish is applied.
If you want pre-painted materials and are willing to work with mdf, ever consider melamine or pre-finished plywood as an option?
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#2 posted 06-03-2014 04:30 AM
I do it with mdf moulding. Don’t see why it wouldn’t work.
JAAune
#3 posted 06-03-2014 04:31 AM
Fridge does bring up a good point. Are these pieces only visible on one side or two? It’s the backside that gets scratched up when feeding sheets through a table saw. The top face stays nice and clean.
View Matt in Franklin's profile
Matt in Franklin
294 posts in 1577 days
#4 posted 06-03-2014 11:54 AM
The method I used on some MDF panels for the sides of a cabinet was to cut the panels to final dimensions, then prime and paint them, and then assemble.
-- Follow me on instagram and facebook @mwawoodworks , http://instagram.com/mwawoodworks/, https://www.facebook.com/MWAWoodworks
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2036 days
#5 posted 06-03-2014 11:57 AM
+1 Matt at the least prime before assembly.
-- Who is John Galt?
View MrRon's profile
MrRon
4711 posts in 3207 days
#6 posted 06-03-2014 09:42 PM
I assume you are painting by brush. The problem with painting prior to cutting/assembling, is you have to wait for the paint to dry before doing anything further. Maybe priming is ok, but there will still be some drying time required.
View ChuckC's profile
ChuckC
828 posts in 2899 days
#7 posted 06-03-2014 09:49 PM
A track saw or track jig for a standard circular saw is an option too.
If spraying is an option I would cut, assemble, and then spray.
buck_cpa
#8 posted 06-05-2014 04:29 PM
Thanks for the replies. I decided to cut, dry fit, paint, then assemble. Been painting for 12 hours now – 17 sheets of mdf takes a while. I’ll post pics when i finish our closet.
