old lathe problem
« back to Woodturning forum
Forum topic by tikirawker posted 06-01-2014 08:05 PM 1696 views 0 times favorited 15 replies Add to Favorites Watch
View tikirawker's profile
tikirawker
8 posts in 2685 days
06-01-2014 08:05 PM
Topic tags/keywords: turning vintage lathe help lathe
Hello
I am new to turning wood but so far I enjoy it! :)
I bought an old lathe and I want to try and turn pens and smaller items.
The lathe itself has a 3/4” shaft (male side) that is spun by the motor.
The center pin or plate (for bowls) is attached by a set screw (female side).
From what I see to turn pens it works best by attaching a chuck similar to a drill.
Where would I find a chuck like that?
Is this a common problem for newbies?
I will attach a photo to the bowl plate as my description may be a bit crude.
Thanks
-Matt
15 replies so far
View PaulDoug's profile
PaulDoug
1537 posts in 1703 days
#1 posted 06-01-2014 08:20 PM
I don’t know what lathe you have, but the first thing I did when I wanted to start making pens years ago was order this free DVD from Penn State Industries. http://www.pennstateind.com/store/DVD.html?prodpage=1DV It showed me the type of set up I would need to get started. There is also a lot of info you You Tube that will help.
You need a pen mandril for the headstock. The drill chuck if for drilling the blanks. It goes into the tailstock. You can also drill the pen blanks on a drill press. There a lot of things to learn, more than could all be explained here. And what you use will depend on what will work on the lathe you have. It is worth it to get a book, or video, or BEST, if you have a friend that is a pen turner, get with him/her.
View Wildwood's profile
Wildwood
2305 posts in 2134 days
#2 posted 06-01-2014 10:11 PM
Really need to know if your headstock spindle has a Morse taper or simple ¾” x TPI threads. Most ¾” spindles normally have a MT1 Morse taper. Threaded spindles (no Morse taper) either ¾” x 16TPI or ¾” x 10 TPI.
You will need a mandrel and other pen turning accessories to turn pens.
http://www.pennstateind.com/store/pen-mandrels.html
Hard to provide you a list of accessories not knowing what lathe & specs you are working with.
-- Bill
tikirawker
#3 posted 06-01-2014 10:32 PM
I show have mentioned by old I meant zero markings or stamps.
The easiest way to picture my set up is look at the base of 3/4 drill bit.
That’s it. Just 3/4” of solid steel steel (no taper or anything similar).
The stuff at pennstate seems to all be a male end that fits into the female end.
I need the exact opposite.
Where would I find a mandrel to work with that?
I would prefer to keep it under 50-60 bucks.
Here is another photo of the entire lathe.
tikirawker
#4 posted 06-01-2014 10:50 PM
here are a couple more photos
tikirawker
#5 posted 06-02-2014 01:49 AM
View Woodknack's profile
Woodknack
11626 posts in 2379 days
#6 posted 06-02-2014 02:15 AM
You’ll probably have a devil of a time tracking down anything besides spur centers to fit that.
Wildwood
#7 posted 06-02-2014 02:46 PM
I have a lathe with Morse taper MT2 and often turn pens between centers using a dead center mounted in the headstock and 60 degree live center in the tailstock. Also have three different pen mandrels.
Looking at your lathe not sure what that thing with point and spurs all about and cannot tell what you have in the tail stock. If could replace that spur drive which mounts on headstock with a dead center and put a dead center in the tailstock might be able to turn pens. Single barrel pen kits no problem, depending upon kit bushing could turn two barrel pen one at a time.
-- Bill
tikirawker
#8 posted 06-03-2014 04:27 AM
http://www.ebay.com/itm/151201630566?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I found this on fleabay.
I think if I took this to a machine shop to have a couple holes for set screws drilled and tapped I could get to a familiar headstock of 8tpi. then I think I can buy a universal mandrel from pennstate or a similar company.
any comments or ideas??
Woodknack
#9 posted 06-03-2014 07:28 AM
Wildwood
#10 posted 06-03-2014 10:31 AM
You can spend a lot of time and money trying to get that old lathe ready to turn pens and end up disappointed. I would use it for simple spindle projects and look into look for something like this where can buy standard pen turning accessories.
http://www.harborfreight.com/5-speed-bench-top-wood-lathe-65345.html
If you would look through this book on lathe nomenclature, components, and accessories might help you understand what we are talking about.
http://wood.woodtools.nov.ru/books/lathe_book/lathe_book.pdf
-- Bill
View TheDane's profile
TheDane
5423 posts in 3662 days
#11 posted 06-03-2014 02:00 PM
tikirawker—Wildwood Bill is right … trying to find parts and retrofit that lathe is likely to be a frustrating and unrewarding experience. The Ernie Conover book that he provided a link to is a bit outdated (written 13+ years ago), but is still an excellent resource for a beginning turner trying to learn the lay of the land.
tikirawker
#12 posted 06-05-2014 05:28 AM
Awesome advice thanks.
I may need to hawk craigslist again for a mini lathe…
View ibewjon's profile
ibewjon
38 posts in 2792 days
#13 posted 07-05-2014 02:07 AM
this looks like my first lathe, i think it might have come from sears, before the craftsman name. if i remember correctly, mine says Dunlap or Dunlop on it, but it is in the attic and i do not remember. the tailstock is a dead center shaft, with a point in the middle that needs grease against the wood, and the headstock has a solid shaft that needs setscrew drive spur, and the headstock has a three sheave pulley for adjusting the speed. keep it for a wall hanging. I got my first mini lathe for $100 at a home center, the same one that penn state and harbor freight sell. It works fine for pens and small turnings, and cheaper than retrofitting the old one. I just purchased a powermatic 90 lathe, and am looking to find the proper size sheave for the motor, [1725 rpm], and the proper motor to headstock drive belt if anyone has this info. thanks, jon
View Knothead62's profile
Knothead62
2584 posts in 2960 days
#14 posted 07-05-2014 11:49 PM
Get a quality lathe and keep the old one for funsies. Are you aware that you will have more in accessories than the lathe itself? Go to www.woodturner.org for tons of info on turning. You can also look for a local chapter of AAW. The chapters are well worth the effort to learn about turning.
View Kenbu's profile
Kenbu
31 posts in 1880 days
#15 posted 07-06-2014 01:07 PM
You can certainly turn pens, spindles and other similar items between centers using that lathe and a drill press for drilling, as well as small faceplate work—assuming you have or can find/make a tool rest. Invest in tools you’ll be able to use with your next lathe. Upgrade when your skills outgrow this one (and by then you’ll have a better idea of what to look for). I suggest you look into the wealth of information and assistance available at the International Association of Pen-turners site, http://www.penturners.org.
Ken
