Forum topic by castlebed | posted 06-01-2014 08:03 PM | 1664 views | 0 times favorited | 8 replies | ![]() |
Topic tags/keywords: unisaw motor upgrade tablesaw I need some assistance in replacing the motor in my 1944 Unisaw I plan on buying a LEESON 1.5hp replacement motor but I cannot find info. on what size pulley I need to run it I was told I have to get a different one then the 5.25 that is currently on the RI bullet motor -- Mitch |
8 replies so far
#1 posted 06-01-2014 09:55 PM |
Go to owwm.org Ask there and you’ll have your answer within minutes. |
#2 posted 06-01-2014 10:23 PM |
Unisaw made two pulley sizes. One for the 3500rpm and one for the 1740. The bigger one would be for the 1740. If the new lesson is 1740, you need the same pulley size, but check the motor shaft diameter. If it is 3500 you’ll need 3.5”. http://www.sawcenter.com/unisawparts.htm May I ask why the “upgrade”? -- I came - I sawed - I over-built |
#3 posted 06-01-2014 10:27 PM |
If you don’t mind my 2 cents |
#4 posted 06-02-2014 12:19 AM |
Thank you for the knowledge just would like to keep the Original motor healthy seems to be slowing a little -- Mitch |
#5 posted 06-02-2014 12:58 AM |
+1 to the TEFC motor, if your current RI motor is starting to slow, dust accumulation on and in the commutator could be part of the problem. An enclosed motor would help prevent this from happening again. In all likelihood the replacement spins at roughly twice the speed of the old motor necessitating a pulley of half the diameter, and shorter belts as well. The folks at owwm.org would probably be able to tell you not only the pulley you need, but the correct belt size also without having to measure anything on your own. |
#6 posted 11-29-2014 08:14 AM |
Thank you everyone who replied to my question ToddJB thanks I purchased a 2hp TEFC 3450 rpm motor would that still use the 3.5”pulley? thanks August McCormick Lehman III I did buy a TEFC motor should have it in a couple days and last but not least thanks bigblockyeti I am a member of owwm.org I will check with them thanks everyone -- Mitch |
#7 posted 11-29-2014 12:12 PM |
Probably a bit late, but be aware your new motor will not fit an un altered saw cabinet and allow 45 degree angle cuts at all extensions. The original motors are prized for that reason. |
#8 posted 11-29-2014 07:10 PM |
Thanks Minorhero The cabinet to my unisaw was already manipulated for an aftermarket motor universal mounting brackets were fabricated at the Douglas aircraft facility were the saw was originally used -- Mitch |
Forum | Topics |
Woodworking Skill Share
12029 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6695 |
28059 |
CNC Woodworking
212 |
Hand Tools
5410 |
Jigs & Fixtures
1419 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
