best kind of saw for...
Forum topic by mzimmers posted 06-01-2014 01:43 PM 1385 views 0 times favorited 21 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
200 posts in 3938 days
06-01-2014 01:43 PM
...cutting very small pieces of hardwood? I make some spline boxes (I’m sure many of you have seen the plans online) that call for little triangular pieces about 1/8” thick. I can create the triangle profile fairly easily on my table saw, but…what would make it easier to knock out the 1/8” cuts?
Band saw? Scroll saw? Something I’m overlooking? Currently I do it on my miter saw, which apart from the 50% waste, gets a little tedious looking around the shop for wherever the saw threw the little piece just after cutting it.
Thanks for any ideas…
-- M. Zimmers
21 replies so far
View TiggerWood's profile
TiggerWood
271 posts in 1629 days
#1 posted 06-01-2014 01:54 PM
I work with small pieces and find the scroll saw to work best.
mzimmers
#2 posted 06-01-2014 01:55 PM
Thanks, TiggerWood. Do you have a particular technique for cutting exact thicknesses? This is a big time-saver in making these parts.
-- M. Zimmers
TiggerWood
#3 posted 06-01-2014 02:04 PM
After a little Googling, it seems that the best approach is to make a spline jig for the table or miter saw. Just Google spline jig.
Basically, I guess you would cut the thickness first and then go to town cutting all the splines, I think.
Hmm, they have jigs that work either way. Your choice.
TiggerWood
#4 posted 06-01-2014 02:16 PM
Thanks for posting this question. I’m learning a lot from it.
View Jim Finn's profile
Jim Finn
2657 posts in 2944 days
#5 posted 06-01-2014 02:31 PM
I make thin pieces myself and cut the thickness first non my table saw, then the shape. Just as TiggerWood suggested.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View docholladay's profile
docholladay
1287 posts in 3081 days
#6 posted 06-01-2014 02:46 PM
What about a quick simple hand tool option? I would use a good fine tooth back saw. A Japanese style pull saw has a very thin kerf. Almost zero waste and cuts fast. If you need precision, use a bench hook or some type of miter box you can build yourself.
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
117114 posts in 3599 days
#7 posted 06-01-2014 03:54 PM
A thin stock ripping jig will do the job.Here’s one Matt made.
http://lumberjocks.com/projects/84494
View NiteWalker's profile
NiteWalker
2737 posts in 2599 days
#8 posted 06-01-2014 05:37 PM
I cut the strips on the table saw, the triangle shape on the bandsaw (less waste).
I don’t use a thin strip jig; I use a sacrificial pusher with the stock between the fence and blade. With a riving knife and pusher, it’s plenty safe.
mzimmers
#9 posted 06-01-2014 05:47 PM
Thanks for all the suggestion, guys. All the options are good, but it sounds like the one that suits my needs best is NiteWalker’s.
Now…if I can just figure out to keep the saw from tossing the little triangles into the dark corner of the garage and/or the vacuum from sucking it up. Maybe a little 1/8” block between the riving knife and the fence? The cut stock’s never going to get that far.
-- M. Zimmers
View muleskinner's profile
muleskinner
896 posts in 2459 days
#10 posted 06-01-2014 06:24 PM
I’ve done a few splined miters. I use the planer to get the thickness first. Then just cut chunks for the splines. Trim and sand after gluing.
-- Visualize whirled peas
View gfadvm's profile
gfadvm
14940 posts in 2712 days
#11 posted 06-02-2014 12:25 AM
I plane stock to the exact thickness to fit the spline slot, then cut slightly oversized triangles with the little bandsaw.
View bigblockyeti's profile (online now)
bigblockyeti
5135 posts in 1743 days
#12 posted 06-02-2014 01:01 AM
If you’re already starting with fairly small strips, the bandsaw would probably be the safest route, also fairly small kerf to if your cutting something pricey (like ironwood). A good tablesaw jig would be more likely to leave a finish that required little if any sanding before installation, but much larger kerf if your cutting down something with any substantial width.
mzimmers
#13 posted 06-02-2014 09:42 PM
I haven’t tried planing to 1/8” yet. I have a DeWalt DW735 with the Byrd cutter; I know that’s about at the ragged edge of what it will do. Worth a try, I suppose.
Getting the thickness exact is more important to me than getting the other dimensions right. I can always use a trim router bit to clean up any extra, but if the thickness isn’t right, it makes insertion a real chore.
-- M. Zimmers
gfadvm
#14 posted 06-03-2014 12:27 AM
If you double face tape your stock to a flat board, you can plane thinner than 1/8”. Just take really small ‘bites’ when you get close to the final thickness. I usually use my drum sander to thickness my splines but have used the planer in the past and it worked fine.
View bonesbr549's profile
bonesbr549
1557 posts in 3089 days
#15 posted 06-03-2014 03:15 AM
here ya go
http://youtu.be/3ruwZdaPjbs
