Finishing walnut
Forum topic by steve223 posted 06-01-2014 10:32 AM 1301 views 2 times favorited 5 replies Add to Favorites Watch
View steve223's profile
steve223
20 posts in 2943 days
06-01-2014 10:32 AM
I’m doing a small project in walnut and I am not sure what to finish it with. I don’t want to make the wood any darker but I do want to bring out the grain. Any suggestions? Thanks.
-- steve223
5 replies so far
View The Box Whisperer's profile
The Box Whisperer
678 posts in 1944 days
#1 posted 06-01-2014 10:34 AM
I love Danish oil, wait 3 days for it to cure then poly on walnut.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View mahdee's profile
mahdee
3830 posts in 1641 days
#2 posted 06-01-2014 01:49 PM
+ The Box Whispere.. I use teak oil.
-- earthartandfoods.com
View rustfever's profile
rustfever
743 posts in 3184 days
#3 posted 06-01-2014 01:58 PM
Start with Watco Danish neutral and give a good coat. Wipe excess off and set aside for several days. Then use the Beall three step wax system. But be careful and put your dark glasses on!. The grain of figured walnut will POP out at you.
-- Rustfever, Central California
View Duckster's profile
Duckster
357 posts in 1224 days
#4 posted 09-27-2014 02:34 AM
I have done several projects in Walnut and I finish with 7 to 9 coats of Lacquer. I let it dry for two or three weeks. This lets the Lacqure completely dry. I use a instrument type Lacqure.
I then use a 2000 grit pad on my dual action sander. I use soap water to help keep the pad clean of dust. I am supposing you used a wood filler to eliminate any pores in the wood. I then use a 4000 grit before I put a 4000 grit polish on it. This keeps the wood from looking dark and puts a mirror finish on your project.
I’ve got some of the finishes on my project sight.
-- Duckster, Texas. {Any day of fishing, Beats a good day at work.} Wash your feet and love Jesus
View JAAune's profile
JAAune
1772 posts in 2190 days
#5 posted 09-27-2014 10:20 PM
I usually put some dark pigment (preferably Watco dark walnut) on walnut to minimize fading over time. Pigments are more light-fast than walnut. It does darken the wood a little but not a lot.
Sometimes I’ll just use Minwax Natural stain (which has no pigments) but only if I don’t care about fading over time.
