Question about converting a Turbine HVLP cup gun to pressure pot
Forum topic by David Drummond posted 06-01-2014 02:56 AM 1325 views 0 times favorited 0 replies Add to Favorites Watch
View David Drummond's profile
David Drummond
97 posts in 2903 days
06-01-2014 02:56 AM
Topic tags/keywords: fuji q4 pressure pot
I have a Fuji Q4 pro that I would like to set up to use a pressure pot instead of the siphon quart cup it comes with for multiple reasons but am unsure of how to go about achieving this. Has anyone done this before? I would assume since the air supply comes from the turbine all I should have to do is unthread the fittings that connect the cup to the gun and just connect a remote fluid line and just pressurize the pressure pot with an air compressor and that would be it. Just seems like there is something I am not taking into consideration. Any advice from anyone who has done this would be appreciated.
Thanks!
David
-- "Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do... Explore, Dream, Discover” Mark Twain
0 replies so far
