Forum topic by fustyducker | posted 05-31-2014 10:30 PM | 5873 views | 0 times favorited | 11 replies | ![]() |
Topic tags/keywords: box hardware question Anyone know of a source for the brass bars use to make up cantilevered trays that pull up and out, like in a tackle box? Also need shoulders screws to act as a bearing for the bars. The pix shows an example of same in a jewelry box; note the side opening trays. I’ve looked everywhere and found absolutely nothing, don’t even know what these things are properly called! Sure I could make some up out of brass bar or sheet stock but I would much rather grab something stock of the shelf and spend my time makin’ sawdust… |
11 replies so far
#1 posted 05-31-2014 10:51 PM |
I think I saw something like that in the Lee Valley hardware catalogue. I think they were for a sewing box, but its really the same application. -- "Checking for square? What madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#2 posted 06-01-2014 01:00 AM |
Don’t know about brass bar stock, but here’s the hinge mechanism from Rockler -- You've got to be smarter than the tree. |
#3 posted 05-10-2017 03:46 PM |
Hey fustyduster, I’d like to get the plans to that Jewelry box. Does anyone know where those plans are or where I could find plans for one like it (with the lift trays). |
#4 posted 05-10-2017 04:26 PM |
Hey Fusty. Point me to the plans as well. |
#5 posted 05-10-2017 06:20 PM |
No, but they can be done with hardwood. |
#6 posted 05-10-2017 11:12 PM |
Nice, and thank you but I’m looking more toward the Jewelry box look vs. the tackle/sewing box version. |
#7 posted 05-11-2017 12:23 AM |
Try the word “cantilever” in your search |
#8 posted 05-11-2017 12:56 AM |
Brass strips are available at mcmaster.com. . . m |
#9 posted 05-11-2017 09:21 AM |
Just brass strip stock or the mfg hinges? Is there a type of hinge I should search for? “Strap” hinges brings up the gate type hinge. |
#10 posted 05-11-2017 08:42 PM |
You do not want hinges, you do want pieces of brass bar stock. Cut it to length, drill the holes and countersink for brass screws. That is how I made the bars for the drawer lift mechanism in this jewelry box. I made a simple jig to round the ends of the bars. I took a scrap piece of 1/2” baltic birch plywood and inserted a pin that was the diameter of the hole in the wood spaced 1/2 of the width of the bar stock away from the edge. With the bar stock placed over the pin the edge of the stock would be parallel to and exactly along the edge of the plywood. I then clamped the jig to the table of my vertical belt sander with the edge right at the belt. Slowly pivoting the piece around the pin gives a perfectly rounded end. Cleanup with some fine grit sandpaper and a bit of buffing gave a great finish to the bars. I got my bar stock from onlinemetals.com. I have used them in the past and they have a great selection, good prices, and rapid shipping. |
#11 posted 05-11-2017 10:28 PM |
Well, Kazooman, what can I say, between your explanation and the pictures, I’m impressed, really. Do you have a website, sell on line? Thanks for responding. |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28053 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4755 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
