fixing bad seem in table top glue up
Forum topic by jimmy J posted 05-31-2014 03:44 AM 1947 views 0 times favorited 5 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2429 days
05-31-2014 03:44 AM
So i’m finally finished my table top glue up. It looks pretty good, but there is a spot on one seam about 12” long in the middle of the table where it looks like there is a small gap between the boards – see first pic, and for a comparison to a clean seam, see the second pic. when i say gap, i mean the boards a slightly separated, but there seems to be glue filling in the gap. I haven’t yet sanded it down but my guess it that it is this way throughout the thickness of the board.
Any thoughts on what to do about it, to minimize the effect after finishing? The boards are maple, and I intend to dye stain it relatively dark (trans-tint vintage maple), via spray, then top with Arm-R-Seal. I used TB2 for the glue, and am fearing that the thin line of glue would not take the dye / topcoats? was contemplating trying to scratch the glue down a little, then add a little epoxy which i believe would take the dye a whole lot better. Worth the effort? Or other ideas? The client is me and I’m in no rush, so will do what needs to be done if it will help.
5 replies so far
View RogerInColorado's profile
RogerInColorado
321 posts in 2004 days
#1 posted 05-31-2014 04:11 AM
I’d wipe it down with some naptha or mineral spirits and see if glue shows up before I did anything else.
jimmy J
#2 posted 05-31-2014 04:21 AM
Thanks Roger. You can see the glue while the boards are dry, and also with a water spritz. Its a dark line at the seam
View levan's profile
levan
472 posts in 3029 days
#3 posted 05-31-2014 02:28 PM
I think I would try filling the void with glue and sanding,while glue is still wet. If you can get enough saw dust mixed with the glue it may blend. Short of that if your top is wide enough, rip out joint and try again.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
5013 posts in 2543 days
#4 posted 05-31-2014 03:17 PM
It’s very hard to conceal something like that, consider ripping it apart right through the seam and regluing. This would probably cost you 1/4” or so in width after jointing, so it may not be possible.
View newwoodbutcher's profile
newwoodbutcher
746 posts in 2900 days
#5 posted 06-20-2014 05:38 AM
I would either rip the seam and rejoins for a good fit. Or, lay an inlay strip of contrasting wood (make it a feature) or a subtle inlay that blends but stands out. I would not try to fill the gap to hide it with glue or any other filler.
-- Ken
