Filling Ambrosia maple holes
Forum topic by Gixxerjoe04 posted 05-30-2014 07:16 PM 4527 views 0 times favorited 13 replies Add to Favorites Watch
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1694 days
05-30-2014 07:16 PM
I’m about to make a serving tray out of some ambrosia maple. What’s a safe filler for the holes left by the beetle? Didn’t know if epoxy would be good to use, the holes are pretty small and epoxy is pretty thick, figured it might be hard to fill with.
13 replies so far
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#1 posted 05-30-2014 07:24 PM
Most often I use super glue and a contrasting sanding dust. Recently I tried black gasket sealer, it was okay, looks nice but tougher than you’d think to fill in the holes. Epoxy dyed or mixed with dust will work. I’ve been wanting to try dyed fiberglass resin, cheaper than epoxy.
View Marcus's profile
Marcus
1163 posts in 2136 days
#2 posted 05-30-2014 07:28 PM
I used “ebony” wood filler on the last couple ambrosia maple projects I did. I was pleased w/ the results.
Gixxerjoe04
#3 posted 05-30-2014 07:29 PM
Hmmm, so you use maple or something lighter in color than the streaks to show the holes i guess? I have some super glue but it’s pretty thin and might be a pain as well.
Marcus
#4 posted 05-30-2014 07:29 PM
Hard to see because the pictures are from further away, but it makes the holes stand out a bit against the rest of the lumber which I personally like…its why we go after wood like this!
http://lumberjocks.com/projects/78811
Gixxerjoe04
#5 posted 05-30-2014 07:35 PM
I’ve seen that table when googling things made from ambrosia maple, and that’s one awesome table, if i had the skill I’d probably use the maple i got and try to make one like that, but that’ll have to wait.
View Monte Pittman's profile
Monte Pittman
29788 posts in 2455 days
#6 posted 05-30-2014 07:50 PM
I use epoxy glue and then send them down when cured.
Woodknack
#7 posted 05-30-2014 07:59 PM
What I do is dump sanding dust over the holes and work it in with a 2” scraper, scrape off the excess then go back and dot over the filled holes with ca glue, wait a couple minutes then sand. Troweling on thinned wood filler would be easier but wood filler sucks and epoxy is too expensive to trowel. If you go with epoxy I recommend using dye or food coloring, epoxy and sawdust looks muddy.
View Dabcan's profile
Dabcan
255 posts in 2788 days
#8 posted 05-31-2014 12:07 AM
I used to fill them with epoxy, then one day I decided I liked the look with them unfilled…
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
View richardwootton's profile
richardwootton
1699 posts in 2072 days
#9 posted 05-31-2014 12:14 AM
I personally like the look with them not filled. But I guess that could be an issue with debris getting in there and difficult to get out.
-- Richard, Hot Springs, Ar -- Galoot In Training
View gfadvm's profile
gfadvm
14940 posts in 2807 days
#10 posted 05-31-2014 01:11 AM
Shellac mixed with fine sanding dust makes a quick and easy filler. If it gets stiff/dries while you are working with it just add a drop or 2 of alcohol or thinned shellac.
View Yonak's profile
Yonak
986 posts in 1638 days
#11 posted 05-31-2014 02:47 AM
I’ve always filled ambrosia beetle holes with Rock Hard water puddy colored with water-based paint, as long I wasn’t going to use a non-drying oil finish.
Woodknack
#12 posted 05-31-2014 03:05 AM
Hmm, nice tip about shellac and dust, have to try that.
gfadvm
#13 posted 05-31-2014 01:52 PM
I save the dried up leftover in a Skoal can and “reconstitute” it when needed with a few drops of alcohol or diluted shellac.
