Need some help with ideas on how to fix this please
Forum topic by Jerry posted 05-30-2014 07:07 PM 1200 views 0 times favorited 12 replies Add to Favorites Watch
View Jerry's profile (online now)
Jerry
2634 posts in 1643 days
05-30-2014 07:07 PM
Topic tags/keywords: question plywood veneer finishing refurbishing modern
I have been advertising in Craigslist for doing small repairs and refinishing on furniture. I got a client yesterday that has this chest of drawers that she wants the corner of the door repaired. I’m pretty sure this is going to be plywood and she’s already informed me that the door is veneered, and she does not want to go to the expense of re-veneering the whole door.
I’ve been trying to come up with some sort of idea to make this corner look a little better, but so far nothing comes to mind that seems like a permanent repair.
If I use wood putty and shape and stain it, it may fall off later, so that does not seem like an option. I could sand it and stain it but the damage would still be there, just not so evident.
Any ideas would be greatly appreciated.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
12 replies so far
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#1 posted 05-30-2014 07:24 PM
Short of trimming the top of the door off and adding a trim strip, that is a tough repair. I wouldn’t be surprised if it is actually veneered MDF.
View Woodknack's profile
Woodknack
11608 posts in 2375 days
#2 posted 05-30-2014 07:26 PM
From the angle I can’t see the extent of the damage. Is the corner actually chipped off or just the veneer?
Jerry
#3 posted 05-30-2014 07:28 PM
Willie, you are right, it may very well be MDF, I hadn’t thought of that, if that is the case, then there is probably no hope.
Rick, yes, the corner and the veneer are chipped off.
View Marcus's profile
Marcus
1163 posts in 2014 days
#4 posted 05-30-2014 07:31 PM
ack, for damage that minor (hard to judge from the pictures), I think most anything you do would only make it look worse. I think just a few dabs of color matched stain would be about the best solution.
View mahdee's profile
mahdee
3883 posts in 1762 days
#5 posted 05-30-2014 07:38 PM
Hi Jerry, just an idea… Get a strip of wood and make a frame that goes all the way around 3 sides of each door. Fill in the gap with colored epoxy. Good luck.
-- earthartandfoods.com
mahdee
#6 posted 05-30-2014 07:40 PM
It may have to go on all 4 sides to look good…
Jerry
#7 posted 05-30-2014 07:49 PM
Marcus and mrjinx007 thanks for your thoughts. At this point, I’m leaning toward the stain. The epoxy is a good idea as well, but I don’t think she will want to pay for the amount of time it would take.
View Earlextech's profile
Earlextech
1161 posts in 2685 days
#8 posted 05-30-2014 07:54 PM
I’m with marcus on this. If she’s already put a limit on cost I wouldn’t waste too much of my time. Sand, maybe a little filler and stain it.
Woodknack
#9 posted 05-30-2014 08:06 PM
Patch in a piece of veneer and fill behind it with solid wood, stain to match. The furniture is probably not worth the effort but if you go above and beyond you’ll get word of mouth business.
Jerry
#10 posted 05-30-2014 09:00 PM
Great suggestion Rick. Thanks.
View EPJartisan's profile
EPJartisan
1118 posts in 3120 days
#11 posted 05-30-2014 09:17 PM
I’ve done this before.. since it is walnut I have a fix that may work for you.. Go with the veneer and fill behind..
~ grain match the veneer but tooth joint the new veneer on the existing face… (with a very slight overlap and in the grain direction)
~ use a clear epoxy…clamp tight for a moment for squeeze out,
~ but then before it cures take a exacto blade and fur both the existing face and the new veneer so the blend the fibers and to match the walnut open grain and figure…. put a tiny bit more epoxy on and clamp until cured.
~ then use a scraper card to flatten the overlap…
~ if there is any glue lines use the exacto blade again to break the grain and epoxy again.
It takes some practice
-- " 'Truth' is like a beautiful flower, unique to each plant and to the season it blossoms ... 'Fact' is the root and leaf, allowing the plant grow and bloom again."
Jerry
#12 posted 05-30-2014 11:23 PM
RE EPJartisan: Wow! Thanks a lot. That is a really refined technique. I really appreciate the instruction.
—Jerry
